dually axle conversion question
Old Jan 6, 2003 | 02:57 PM
samtheham's Avatar
How hard would it be to convert a dually axle to a normal type axle setup ( IE two tires as opposed to four )
Old Jan 6, 2003 | 04:41 PM
gitchesum's Avatar
Re:dually axle conversion question
From the few folks that I have talked to, I've learned the rear-ends are the same width. It's the cab and chassis rear axle that is narrower.<br>You would need a new bed, shorter wheel studs for the rear axle and new fron roters. Other than a new set of single wheel, I can't think of anything else that would require changing. <br>Someone else might have more info. I'm considering the same project. <br><br>Of course if you can find someone that wants to convert thier 3/4 ton to a 1 ton, your in luck.
Old Jan 6, 2003 | 05:14 PM
Shovelhead's Avatar
Administrator / Scooter Bum
Something else to consider,
Depending on the year and fender design, the body under those &quot;training wheel fenders&quot; has some VERY ugly holes around the fuel filler and fenderwell cut-outs that those pretty wheelboxes hide.
Old Jan 7, 2003 | 06:17 AM
Dieseldude4x4's Avatar
I asked the same thing a while back cause my son wants a 3500 but with only four tires.
Old Jan 8, 2003 | 03:02 AM
BJK's Avatar
BJK
Maybe find somebody localy with a 2500 that wants dualls, and swap hardware?
Reapertura
Jul 16, 2012 09:31 AM
cletus
Jul 6, 2011 11:31 AM
dparker
Nov 30, 2010 10:00 AM
dzl_damon
Apr 8, 2010 06:27 AM
ridofpwrstroke
Aug 25, 2006 05:24 PM
