W250 dually conversion axle wrap?
Old Jul 12, 2012 | 10:45 PM
Reapertura's Avatar
My truck has a dana 80 I believe under the rear and tonite my friend saw that as I let the clutch out while holding the brakes that the rear end would move up about 2 or 3 inches and appeared to be moving side to side at the same time. The ubolts have some sort of nut spacers on them and I cannot get the nut off to remove the spacer/castle nut. When I try to break them loose the top of the bolt will slide a inch or so on top of the leaf pack! also the what appear to be 6 inch lift blocks are hanging about a 1/4 inch of the perch in the front. Are these issues my problem? I'm thinking yes haha. also the nut on the ubolt is 9/16 so if anyone knows what size ubolts I will need. any input is appreciated.
Old Jul 13, 2012 | 09:25 PM
user name's Avatar
I believe the stock ubolts are 5/8 and they should not move on the spring if properly tightened. If this is a 4x4 and the 6 inch blocks have a spot to hit the bump stop they are factory and while not the best set up they shouldn't be an issue under "normal" use.
Old Jul 15, 2012 | 04:04 PM
Reapertura's Avatar
They do have the factory provision for the bumpstop to hit and it is a 4x4. if the ubolts should be 5/8ths shouldnt the nuts be 5/8ths as well?
Old Jul 16, 2012 | 09:31 AM
enafzige's Avatar
Yes, but you won't use a 5/8 socket or wrench for a 5/8 nut. It should use a 15/16 or 1 1/16 size socket.
--Eric
dagrizz
Jun 26, 2008 01:26 AM
guswheels
Jul 9, 2007 11:51 AM
SmokenRam
Jan 26, 2006 11:22 AM
fireram
13
Jun 23, 2005 05:36 AM
rharveysr
Jul 28, 2004 06:29 PM
