Axle Wrap
Old Jan 24, 2006 | 05:59 PM
SmokenRam's Avatar
Axle Wrap
Well I got most of the lift done on my truck, Has a total of 10inches of lift now. Took if for a drive, and it drove farlly well, Axle wrap was always a consern, so i stood back a watched my buddy do some take offs in it, WOW!! The axle moves ALOT!! So how do i stop this, traction bars or ladder bars? Whats the difference, Does one bolt to the alxe in one point and the other two points?? Or bolt to the alxe or to the spring perch, Help me out here guys, whats the best way to go?? Thanks Chris
Old Jan 25, 2006 | 04:08 PM
SmokenRam's Avatar
I thought for sure someone on here has made there own ladder bars???
Old Jan 25, 2006 | 07:19 PM
blackcloud's Avatar
Are you going to go off-road with thing? If you are I wouldnt go with ladder bars, they will limit your articulation, traction bars should be ok,but thats just my opinion.
Old Jan 25, 2006 | 10:08 PM
AAmeeting's Avatar
How is it lifted? Blocks? 10 inches is a lot. Ladder bars will help but you may think of a four link with some firestone bags. Or if you did blocks get a huge leaf pack.
Old Jan 25, 2006 | 10:10 PM
SmokenRam's Avatar
Don't do much off roading. If I do, its just in mud, no flexing. so thats why I was thinking ladder bars.
Old Jan 25, 2006 | 10:17 PM
SmokenRam's Avatar
Its got 5inch springs up front with 2inch spacers, Rear has a block and add-a-leaf. And also has a 3inch body lift, 10inch Total lift. I know the block thing in the rear is not the best but i don't have to money for new leafs right now, thats why i want ladders to make it somewhat safe. Later down the road it will get new leafs, Long arms and adjustable trac bar.
Old Jan 26, 2006 | 10:05 AM
csutton7's Avatar
I built mine--DOM tubing--1.75 x .25 wall although 2" x .3875 wall may be better--I have a 7" lift---I used 3/4" heims--welded some ears on the bottom of my spring perches so the center of bolt is about 2.5"-3" below axle and then welded some plate steel brackets to the frame---my bars are 8' long--longer is better---chris
Old Jan 26, 2006 | 10:46 AM
yarddog's Avatar
I'm guessing that's a typo? I've been wanting to build bars for awhile too. Since they won't be smashing rocks, you could get away with .120 wall. That would be a lot cheaper than .25 or .19 wall DOM.
Old Jan 26, 2006 | 11:10 AM
SmokenRam's Avatar
You woun't happen to have any pic's? Of how you mounted them?? Thanks-Chris
Old Jan 26, 2006 | 11:22 AM
csutton7's Avatar
yarddog--no that's not a typo--they are 8 feet long---
smokenram--when I have time I'll see if I have a pic or two and email them --there could be a pic or two over at www.diesel-central.com in the photo gallery---chris
Codyboy
Feb 15, 2007 04:03 PM
Dang
Oct 21, 2006 08:22 PM
G1625S
May 16, 2006 07:07 PM
fireram
13
Jun 23, 2005 05:36 AM
rharveysr
Jul 28, 2004 06:29 PM
