Is this considered normal?
Old Jun 30, 2006 | 11:15 PM
wheelo90's Avatar
I dont know if this would be considered normal or not, so I need a little help.
I can mash it to the floor and instead of getting black smoke, I get the grey-ish smoke like a leaking injector on an idle. Is this normal?
The smoke looks like the smoke that you get when you start it up in the mornings. Not Black at all.
Thanks for any help/advice!
Wheelo
Old Jul 1, 2006 | 07:14 AM
Gray smoke is normal on a truck that has enough air for the fuel. Turn up the pump and you will get all the black smoke you can stand.
Old Jul 1, 2006 | 08:55 PM
wheelo90's Avatar
Thanks Wanna,
I never knew that about the grey smoke, I guess I may have to turn the pump up some to get the needed black smoke
Old Jul 1, 2006 | 08:59 PM
gman07's Avatar
I get black smoke until the turbo spools, then it's a greyish haze (time for a hybrid). I also only had grey smoke until I ground the AFC lever and turned the full fuel screw a bit.
Old Jul 1, 2006 | 11:59 PM
edwinsmith's Avatar
Once you've had black, you never go back.
Edwin
NJMurvin
Jun 4, 2012 05:29 PM
reb0957
Nov 17, 2006 06:27 PM
truckjunkie
Oct 5, 2006 10:24 AM
wadem
Aug 26, 2004 11:10 PM
CTD99
Apr 3, 2003 06:36 PM
