Compressor Upgrage?
Old Feb 9, 2009 | 06:14 PM
14racing's Avatar
Compressor Upgrage?
Who out there is running the stage IV compressor upgrade for the h1c and how well do you like it?
Old Feb 9, 2009 | 06:26 PM
pulltilbroke's Avatar
Best Paint (Getrag category)
I got it on my truck, I like it with my mild street tune but when I got a real aggresive tune it aint near enough charger for the fuel
Old Feb 9, 2009 | 09:31 PM
Crazy Matt's Avatar
I just ordered one for my truck today - should be lots better then the stocker.
I'll end up running it till I finish my other mods - a converter or a trans swap?
Old Feb 9, 2009 | 09:41 PM
peobryant's Avatar
I had contemplated getting a comp. wheel upgrade, and did a good deal of research. I found out that if you plan on staying at moderate fuel levels, with stock injectors, it should do pretty good, even if you don't balance it(you are supposed to, by the way...) bu if you get into more mods, such as bigger injectors (370's etc...) than you will need a bigger turbo.
Old Feb 9, 2009 | 09:42 PM
u.s mma's Avatar
i like it. Ive only had mine on for like 6 days, I haven't played with my fuel, and dont' have the snow boost guage hooked up yet so i don' know #. Im suprised at the spool up with the 18.5, I think its a bit faster than the 50 wheel. bit cooler egt's, but with I found myself with my foot on it a lot more. worth the money.
Old Feb 9, 2009 | 09:49 PM
peobryant's Avatar
Well, I just noticed you had a Non Intercooled truck with the 'baby" H1C, so you should like the upgrade quite a bit. But again, only if you plan on having moderate fueling.
Old Feb 10, 2009 | 12:39 AM
Bogurt's Avatar
what kind of injectors could u run safely? im considering doing the same thing with my turbo.
Old Feb 10, 2009 | 01:06 AM
whereswaldo250's Avatar
I love mine and I have a stock truck, and the turbo really talks to you!
Old Feb 10, 2009 | 01:41 AM
I'd say you could run POD's with a mild pump
When I had POD's in my truck with a maxxed pump I could hit 55 psi with a 16cm non gated housing, needless to say it wasn't happy
With my current setup I like it a lot,it spools pretty quick and I can hit 40 psi and it takes a while for the pyro to hit 1300, I'm likin the new I/C
Old Feb 10, 2009 | 02:34 AM
Ace's Avatar
Ace
That depends on what you are planning on doing with the truck. Play truck, run whatever you like and keep an eye on the pyro. But I wouldn't recommend anything more than stock injectors for a working truck. Not even 190s without a bigger turbo, unless you keep the pump turned down. But that sorta defeats the whole purpose then, doesn't it?
Old Feb 10, 2009 | 06:47 AM
jcmoyer2004's Avatar
i have the compressor upgrade with the 14cm housing and absolutely love it. i haven't gone all crazy with the mods but have done quite a bit to the ol girl and it runs great. you can't beat it for the price as compared to a brand new turbo. wish i would have done it when i first bought the truck. just my .02
Old Feb 10, 2009 | 05:38 PM
bmxpxdude's Avatar
I have the stage four from HTT. with some big sticks, a good exhaust and intake, p-pump mine is make 300hp 600lbs....
Old Feb 10, 2009 | 05:41 PM
peobryant's Avatar
What are the EGT's like?
Old Feb 10, 2009 | 06:41 PM
14racing's Avatar
I don't plan on getting to wild with it. Maybe turn the fuel screw in some more and getting a different fuel pin. I'm also hoping to get water/meth this spring. I want to be making 200 to 250 rwhp and be able to use it to tow without getting hot.
Old Feb 10, 2009 | 07:14 PM
RamW350 dually's Avatar
What size is the compressor housing and wheel for the stage IV upgrade? The stage III is 60mm, so I'd think it's larger then that. Dave is running a stage IV compressor upgrade with 6x.016 injectors, which would be larger then a 370 injector for sure. But then again he has the water/methanol which is like a "chemical" intercooling. A truck without it would see higher EGTs especially with a larger injector.
