Clutch suggestions
Old Jun 2, 2009 | 06:38 PM
gwilming's Avatar
Clutch suggestions
Need some suggestions on choosing a new clutch. 92dodge w250 cummins all stock with tow package from factory. Old clutch is a Sachs. I pull a dump trailer occasionally as well as a skid loader from time to time. Should I stick with what came from the factory or something different? Would like to spend between $500 and $600. It has the Getrag 360 5 speed.
Old Jun 2, 2009 | 06:52 PM
bradshaw106's Avatar
i have been doing some research on this subject as well. based on what you have said i would think the stock sachs setup is what you would want. what i have been told that as long as you let the clutch fully engage before rolling the coal the sachs will hold. just doesn't like to be slipped. but someone with more firsthand experience should chime in.
Old Jun 2, 2009 | 07:22 PM
Sachs is the best value for your application.
Old Jun 2, 2009 | 08:02 PM
gwilming's Avatar
The sachs that I have in there is probably original and the truck has 185,000 miles on it. That probably is a good indication on the quality.
Old Jun 2, 2009 | 09:03 PM
jimbo486's Avatar
that clutch should last you quite a bit longer. that is, if you're the original owner and know that it hasn't been driven hard or slipped.
Old Jun 2, 2009 | 10:10 PM
gwilming's Avatar
I bought the truck with 155,000 on it. Whoever had it before did some substantial pulling.
Old Jun 3, 2009 | 12:55 AM
jimbo486's Avatar
have you had it out to look at it? do you know if it's significantly worn to the point of needing a replacement? i've heard that the sachs will easily hold up to about 400hp. given the fact that it doesn't get slipped and is fully engaged before stepping on the go pedal.
Old Jun 3, 2009 | 07:13 AM
BearKiller's Avatar
I have seen nothing in the aftermarket world that is as dependable and long-lasting as the SACHS.
I see them at the diesel shop installing all kinds of trendy name-brand clutches, and I then see them have those fancy clutches in and out a dozen times, trying to get them right, while the guys with 300,000-miles and the original SACHS just keep on driving.
Old Jun 3, 2009 | 07:21 AM
Billut's Avatar
I recall reading about dia. differences, something like 12.25 or so and a "true" 13". I wonder if this is sthg that you should also consider, and if so, does Sachs make a 13" for your application?
Maybe someone will chime in with better knowledge than me.
Old Jun 3, 2009 | 08:08 AM
gwilming's Avatar
I have the tranny at the shop getting rebuilt. I took the clutch out the other night and it seems to be worn on the flywheel side a little bit more than the other. It also seems like the lining is a little loose on the disc itself so for that reason it just seems like the smart thing to do. I don't want to take the tranny down again for a long time. That thing weighs a ton.
Old Jun 3, 2009 | 02:41 PM
jimbo486's Avatar
find yourself a sachs clutch on ebay. for what you're doing, it'll hold up just fine and last you for a while as you've read.
Old Jun 3, 2009 | 03:48 PM
jimbo486's Avatar
to answer billut's question, the sachs that came with getrags in our trucks have 13" clutches from the factory.
steverctx
Mar 20, 2007 05:01 PM
GR40RCapri
18
Nov 14, 2006 08:34 AM
cginwyo
Nov 10, 2006 06:51 PM
hyunsinsone
Oct 2, 2006 12:01 AM
pbolte61
Jun 13, 2006 11:42 PM
