Clutch Release Fork-Remove Trany?
Old Mar 20, 2008 | 09:59 PM
SeenTheLight's Avatar
My clutch release fork has been punched through by the pivot. Do I have to remove the trany to put in the new fork and pivot?
Old Mar 20, 2008 | 10:02 PM
roughstock's Avatar
Yes
Yes.
Think about replacing clutch, when in there. Its easier to do it now, while your in there. (Future Power Upgrades) I learned from expericnce.
Old Mar 20, 2008 | 10:30 PM
torquefan's Avatar
Even if you determine the clutch is still good, a new release bearing and pilot bushing may save future headaches.
Old Mar 21, 2008 | 06:13 AM
angelfire7's Avatar
If you don't have the time or facilitiies to R & R your tranny, the answer is yes you can replace the fork without removing the tranny. If you can remove the tranny the other posters here are correct, just bite the bullet and fix it all now.
Peace,
Joseph
Old Mar 21, 2008 | 09:00 AM
roughstock's Avatar
Peace,
Joseph
How do you get to shift fork out without removing bell housing? You can only pull housing by removing trans, the removing clutch housing? IIRC
Please correct me if I am wrong.
Old Mar 22, 2008 | 07:09 AM
angelfire7's Avatar
The shift fork comes out by removing the rubber boot then grasping the fork with a large set of channel locks and pulling straight out of the bellhousing. It is held in place by clips on a ring assembly next to the bearing that allow the fork to be slid in and out. To get it back in will require a flash light, a 8"-12" flat head screwdriver, and some finessing. Check out the picture. Hope this helps....
Peace,
Joseph
Superduty12v
Dec 20, 2025 06:53 AM
vr1967
Aug 27, 2012 02:29 PM
u.s mma
Sep 20, 2010 10:12 AM
Exekiel69
Sep 19, 2010 08:17 AM
Superduty12v
Mar 23, 2007 04:20 PM
