Clunk when shifting down or reverse
Old Jul 12, 2010 | 07:15 AM
APD's Avatar
APD
1990 automatic with about 285k miles.
Transmission was rebuilt a few years ago. It shifts UP very smooth, even if I stomp on the pedal. But when I let off the pedal quickly and it kicks down into first gear, I get a pretty loud clunk. I get the same clunk whenever I shift into reverse.
What should I be looking for? Im thinking rear end, not a tranny issue?
thanks in advance
Old Jul 12, 2010 | 07:29 AM
93flatbed's Avatar
U joints?
Old Jul 12, 2010 | 07:59 AM
brainfade's Avatar
At 285K the differential may need attention. The open diffs wear out the cross shafts and the limited slips wear out the clutches in both cases creating a lot of slop. I think there's some info in the sticky on this.
Old Jul 12, 2010 | 07:48 PM
dzl_damon's Avatar
I concur. Park the truck on level ground so the weight of the truck doesn't roll against the Park pins in the tranny. Go underneath and rock the drive shaft. When I do this, I have about 1/10th of a revolution in the rear end! My Powr-Lok needs rebuild bad.
Old Jul 13, 2010 | 07:27 AM
NE frmhnd's Avatar
We had a half-ton '82 that had a bad clunk. When you parked it on a hill it would roll about 6 inches before it caught. The spider gear shaft slid out one day during a u-joint replacement and it would only move a couple feet at that point.
Old Jul 14, 2010 | 07:26 AM
APD's Avatar
APD
Well I climbed under the truck and it was pretty obvious what the problem was. I grabbed onto the driveshaft, gave it a twist, and it was flopping around bad. One of the u joint bearings was totally wasted.
Removed the drive shaft, replaced both u-joints, and no more clunk. thanks for the replys.
Jturs
Oct 9, 2013 10:34 PM
Cummins610
17
May 29, 2010 12:50 AM
VikingDiesel
Aug 7, 2007 05:53 PM
MasseyMan1089
May 23, 2007 07:56 PM
dpeder
Feb 21, 2006 11:34 AM
