Clock Spring
Clock Spring
Anyone know where I can score a clock spring for my 91 dodge d-250?? The guy who sold it to me broke it and removed it so I need to get a new one and reinstall it. Please, im tired of forgetting my blinker is on all the time. Ill bet people behind me are like..
Dealer should have one .. Call them an get them to run you vin no. and make sure it doesn't have a recall .. It could have one on the injection pump for sure or the steering wheel ..So it might get close to the clock spring.
Try this link;
https://www.dieseltruckresource.com/...l-t240850.html
You don't want5 buy one from the dealer.
Also OReiles and Ozone might carry them.
Tom
Tom
I thought the clocksprings were only used on the '93 and newer trucks?
I want to put a Grant wheel on mine but they don't make an adapter. I emailed Grant and they said it's because the '93 uses a clockspring.Since i've been contemplating getting a pre '93 column to swap in just so I can use this wheel.
Can anyone clear this up?
Thanks for the tip.. Do you remember the model yr you pulled it out of by any chance?? Also, im gonna de-rail my own thread and ask you what you think of the m2 and m3 fuel pins? I wanna get one after i rebuild the trans but no denny pin for me.. Too much smoke. How do you like the M&H??
Yeah I did the exact same thing. Beats spending some insane amount of money to the dealership for one. Mine costed me $5 though.
I like the pins, makes it much easier to drive and control smoke with a cranked pump. But you still have full fueling!!
So the blinker's don't cancel if your clockspring is broken??? My A/C and horn don't work along with plenty of other issues (cruise control, radio). If the blinker's cancel correctly, does this mean the clockspring is ok??
No, if you take the clockspring out you lose the cams that cancel the blinkers. When the clockspring fails it will usually bind up the steering, you have to pull out the bad clockspring to make the truck safe to drive. I ran without one for a few months, but had to replace it to get the horn back for inspection.
When I broke my clock spring it never scraped or bound or even made a sound, ever. My cruise just wouldn't work and I didn't know why until one day I decided to pull the clock spring and open it up. IIRC (and maybe I don't recall correctly) my horn worked. But then maybe it didn't. Could it even work with a broken clock spring?
I guess it doesn't matter, it's all fixed and works now.
