Chevy or Dodge Dana 60??
Old Aug 24, 2013 | 04:15 PM
TrkEnvy's Avatar
Im converting my 91.5 to 4wd. I have located a dana 60 stash and have my choice of Chevy or Dodge units. Both are 4.10 units and the chevy is 2 inches wider from wheel mount to wheel mount and half an inch wider spring perch to spring perch. Im thinking the slightly wider track would be a good thing, especially because im gonna be changing the Dana 70 in the rear to a 14 bolt. Is there any issue buying the chevy unit and using it under my dodge or should I just buy the dodge unit?? Thanks
Old Aug 24, 2013 | 05:27 PM
93-12Smoke's Avatar
With Chevy parts under it i hope you got a spare grocery getter
Old Aug 24, 2013 | 08:01 PM
TrkEnvy's Avatar
I do have more than one truck.. but seeing as BOTH the dodge AND chevy 60s were made by Dana I think im good. just wanna know from someone w more 60 experience than I if the half inch on the perch will be a prob or if im gonna have issues w the wider track..
Old Aug 24, 2013 | 08:20 PM
93-12Smoke's Avatar
Do you know if the Chevy spring pad is wider? Dodge leafs are narrow.
Old Aug 24, 2013 | 10:20 PM
TrkEnvy's Avatar
now that is a good question. I didnt measure but it looked similar.
Old Aug 25, 2013 | 12:44 AM
comotionman's Avatar
both gm and dodge use 2.5" wide springs.
if you like the wider track get the gm axle. set your truck up to run either spring center.
Old Aug 25, 2013 | 01:16 PM
gyman98's Avatar
What side is the chev pumpkin on?
Old Aug 25, 2013 | 04:21 PM
same as dodge 1st gen.
interesting reading:
http://www.billavista.com/tech/Artic...nt_Axle_Bible/
Old Aug 27, 2013 | 01:12 PM
user name's Avatar
I have a Dodge Dana 60 in the front of my 78 GMC. The Dodge spring pads are about 1/2 inch narrower than the GM's you can make them work and I did but I have always worried about the spring bushings life.
Old Aug 29, 2013 | 06:47 PM
swirv7's Avatar
I put a GM dana 60 under my 92 w250 and i had to squeeze the springs together to get them to fit. The chevy spring pads should be .5 narrower than the dodges. The truck drove fine with the chevy axle but destroyed my shackle bushings.
Listen to comotionman and read the dana 60 bible and you will have alot of questions answered.
SRobertson
Feb 7, 2012 12:38 AM
wreedCTD
27
Sep 30, 2007 09:52 PM
95black2615
19
May 24, 2006 11:05 AM
mcevins
Jul 3, 2003 02:06 AM
Stamey
Apr 18, 2003 10:34 PM
