Cheapest Borgeson Shaft?
Where's the cheapest place to get a borgeson shaft? My old man wants one for his W250. This is a pretty clear cut and dry install correct? Thanks all
Dan
Dan
Summit racing had em the cheapest when I did mine last month. the shaft, and new rag joint went for 180 + delivery. Not bad. I would recommend doing the rag joint while you are in there, that way you don't have to worry about the old one coming apart on the road.
i got mine from the same place i overnighted it for an extra 25 bucks i ordered it friday morn. and had it installed by sat afternoon. it was awsome shipping. plus i got a hat and a bunch of other goodies.
The rag joint is the rubber/fiber joint located above the driver side inner fender using four 12-point bolts to connect the column to the shaft. I have never seen or heard of one ever going bad. Although I suppose if one became contaminated with brake fluid, oil or some other source of deteriorant, it could become degraded or damaged. The one I took out of a 35 year-old Chrysler I parted out a couple years ago looked fine. It doesn't do much exscept provide a soft mount connecting the steering shaft to the steering column.
Thanx for clarifiying, i fixed a seal in the gear box and could not line up the original shaft back on its proper spline, in trying to do so i tore the boot on the rebuildable housing. i have decide to replace shaft rather than spend $10 for the boot and fight with it anymore. i hope im thur with it...
I did mine a couple weeks ago and it was pretty smooth,I had to work it a little to get it to slide on the shaft but it was'nt too bad.Big difference in the steering though.Well worth it.Summit had the best price I could find.
