chassis coating?
Old Nov 9, 2009 | 02:03 PM
oilcan64's Avatar
chassis coating?
pretty soon im gonna strip the entire truck and sandblast the frame. my friend who does truck frames says 2 heavy coats of self-etching primer then 3 heavy coats "mack" black chassis paint
what do you all think?
any suggestions
thanks
Old Nov 9, 2009 | 05:27 PM
Rick 12v CTD's Avatar
When and if I ever do a body off paint job I plan to lineX or Rhino liner the chassis. But things up here are a little different, we have HEAVY salting on the roads to deal with. I've heard of guys in our area doing it with good success so yeah, if I get the chance, I'll be going that route.
As for the chassis paint, I really can't give input I don't know a lot about it.
Old Nov 9, 2009 | 05:58 PM
oilcan64's Avatar
never even thought of that. darn good idea, im sure it would be pricy
Old Nov 9, 2009 | 05:59 PM
on the 91 we POR-15'd the whole frame right over the rust and everything, 2 coats
Old Nov 9, 2009 | 06:14 PM
blackfordd's Avatar
POR-15, talk about pricey!
Old Nov 9, 2009 | 06:17 PM
14racing's Avatar
Yeah, but its good stuff.
Old Nov 9, 2009 | 06:25 PM
DNRCustoms's Avatar
Look at www.kbscoatings.com
I've used por 15 and I am very unhappy about the results after a few years. It peels off, crazy.. I used KBS on my restore of my 92 and it is muche better I feel. the offer a chasis saver kit. Good luck and save up some cash, your gonna need it!!
Old Nov 9, 2009 | 06:27 PM
Trebor's Avatar
I had the crew cab frame sand blasted by my local blaster who used Sherwin-Williams industrial primer and industrial black. This was done to the bare frame with only the engine crossmember and the two last crossmembers in place. I then applied 3M paintable undercoating to the inside of the frame rails and all of the crossmembers. I'm pondering the idea of coating the remaining surfaces with a harder paintable bed liner coating but I haven't decided at this point in time. This was also a 2WD to 4WD conversion. Pictures from yesterday attached.
[IMG][/IMG]
[IMG][/IMG]
Old Nov 9, 2009 | 07:09 PM
johndeere01's Avatar
i just bought some of the Kbs rust stop kit im gonna try it on the 04 see how it works yea it is alittle pricey, but so is a new truck if it works money well spent in my book
Old Nov 9, 2009 | 08:08 PM
speed75's Avatar
i would think rhino and bed liner coatings if they got loose they would totally hide where your frame was being ate by tin worm
Old Nov 9, 2009 | 08:10 PM
oilcan64's Avatar
thanks for all the info
im liking the ksb blacktop chassis coating. think 2 quarts will do the entire frame? id be spraying it three times
Old Nov 9, 2009 | 08:11 PM
oilcan64's Avatar
i couldnt find a reducer on their page either, would you use thinner in this case?
Old Nov 9, 2009 | 08:42 PM
DNRCustoms's Avatar
They offer a thinner, I purchased it when I thought I was gonna spray my underside of the cab. I ended up just brushing it on.
Old Nov 9, 2009 | 08:44 PM
simplysmn's Avatar
I am looking at powder coating frame if time let's me strip it down completly
Old Nov 9, 2009 | 08:57 PM
speed75's Avatar
i think powder would be the cheapest
