Charging system problems
Old Dec 27, 2010 | 07:29 AM
JustRamIt91's Avatar
Charging system.
I found out last night that the charging system on my RC isn't working right... I was good for about 45 minutes then lights out, and then i was playing the "i hope i make it to an outlet" game.
I found the "instructions" that came with the regulator to be less than helpful, considering that my wiring harness has 30 wires and i'm supposed to hook up to 4 of them...
If anybody knows an easy way to "hot wire" the alt so i can manually turn the charging circuit on and off, PLEASE HELP
Thanks,
Nick
Old Dec 27, 2010 | 07:36 AM
I forgot there is a sticky on this...the wiring for the alternator.
I'm still interested in how to hotwire this thing.
Old Dec 27, 2010 | 07:38 AM
Onemoparnut's Avatar
Look in the sticky about wiring an external voltage regulator.
Old Dec 27, 2010 | 09:39 AM
Trebor's Avatar
Full fielding the alternator, as you call "hot wiring", can produce voltages in excess of 20+ volts or more at idle. This is not a good thing to do.
Old Dec 27, 2010 | 12:28 PM
I had a bad regulator, i got a napa regulator and direct wired it and it charges perfect right now. Top dead center of gauge, and it reads 14 volts.
Thanks
Old Dec 27, 2010 | 04:32 PM
TIMMY22's Avatar
It's funny my 92 reads past TDC 1/4" or so. Put the voltage meter on there 14.5V.
My 90 reads 1/4" below TDC put the gauge on there 14.8V.
Go figure
Old Dec 27, 2010 | 06:22 PM
I dont think any of the gauges are very accurate.
Old Dec 27, 2010 | 07:31 PM
The voltage gauge is the most accurate of any gauge in the truck... I need to find a 4spd 318 wiring harness didn't save the one connector i needed
Old Dec 27, 2010 | 07:33 PM
dzl_damon's Avatar
I concur
Diesel-Dan
20
Sep 22, 2019 09:34 PM
Lary Ellis (Top)
Jan 14, 2014 04:49 PM
GLHS
Feb 25, 2011 10:12 PM
DODGER BOMBER
May 13, 2007 12:52 PM
berner
Nov 4, 2006 12:59 AM
