cant get the air out
Old Jan 24, 2008 | 10:50 PM
JBOND's Avatar
ps pump is foaming and hard to steer i jacked up the front end started the rig and turned the wheels to the stops keeping an eye on the fluid level. after about 10 or 12 times the fluid got foamy and the level raised so i quit. did i quit too early. or did i do it wrong. i really need this fixed. driving through the sage brush to feed my horses kinda sucks
Old Jan 24, 2008 | 11:12 PM
ccab85's Avatar
Keep doing what you are doing only with the truck not running. It could take some time, be patient. Seems as if the pump just aerates the fluid when you have it running with no load.
Old Jan 25, 2008 | 10:31 AM
leper's Avatar
Don't turn to full lock. If this problem just started, you have a leak somewhere on the suction side. It could be a line or a pump seal. What happens is that when the fluid is returning and flows over a small hole, it creates suction and pulls air in from the outside, making the foam. I have seen this happen where the hole is too small to leak fluid, but it still sucks air.
Have seen the same on brake systems at a bad flare connection.
Old Jan 25, 2008 | 03:07 PM
JBOND's Avatar
I just bought the pickup. it had been run off the road and layed on its side. boogered up the door and the fender but other than that and the power steering all is ok. the previous owner said the ps pump worked just fine till the wreck. so im guessing thats when air got in the system.
Old Jan 25, 2008 | 04:41 PM
leper's Avatar
Back anf forth it about 50 times with the engine off. Then start it and do it 20 or so more times. Remember NOT to go to full lock.
Old Jan 25, 2008 | 05:17 PM
ChrisLib's Avatar
Sometimes you have to let it sit for several hours till the air bubbles dissipate out of the P/S fluid. If possible I`d let it sit overnight, disconnect the shutoff solenoid so the engine does`nt start, then crank the engine over while turning the wheel. You might have to repeat this process a couple of times (esp if the P/S fluid is old and grungy).
Old Jan 25, 2008 | 08:45 PM
JBOND's Avatar
thanks guys. steering smooth again , it doesnt take three people to turn the wheel anymore. thanks again.
Old Jan 26, 2008 | 06:45 AM
BearKiller's Avatar
Please go into detail as to how you accomplished this.
Thanks.
Old Jan 26, 2008 | 09:31 AM
JBOND's Avatar
1st I blocked up the front and turned the wheels to the stops with the truck off. But I didn't get very much air out so I let it rest awhile (and with the truck off again) turned the wheels--one turn to the left back to center one turn to the right--did this 50-60 times. Then let it rest. Started the motor and turned the wheels 20-30 times and let it rest some more with truck running. I never went clear to the stops the 2nd time I tried it and had better luck. Also I had someone in the pickup turning the wheel while I watched the fluid level and added fluid as needed. Once in awhile I would get a big blast of air out and the level would go way down and want to start pulsing until I put more fluid in.
95black2615
Jul 27, 2009 05:43 PM
SlowSixSpeed
23
Feb 20, 2008 03:01 PM
SjLingenfelter
Oct 24, 2007 08:14 AM
Sixpack73
Aug 21, 2007 10:51 AM
97on22s
24
Feb 15, 2006 09:32 AM
