Can someone identify this Piston Lift Pump?
Very simple.
I got rid of all the hard lines and replaced with rubber.
In the line between the fuel-filter and injector-pump, I installed a TEE that is hose-barbed into the fuel line and has a 1/8-NPT port on the TEE.
Into this port I first screwed a male-female ball-cut-off valve, then a "air and other gases" snubber, then the gauge-line that proceeds through the fire-wall and to the dash-mounted gauge.
A second gauge is laying on the bench that will go in the rubber line ahead of the filter; this one will probably remain under the hood; but then, I might change my mind and put it in the cab also.
On the rest of my fleet, I have temporarily installed the GENO's large-head tapped banjo-bolt, then added everything already listed above.
Every necessary metric adapter, JIC fitting, line, etc., is sorted, grouped, and bagged, one bag per truck, and awaiting time for me to install the piston-lift-pumps and convert them also to rubber lines.
4g63 steve
Sep 3, 2014 10:40 PM
dzl_damon
Aug 29, 2010 11:19 AM
exsanguinate
Nov 1, 2009 07:10 PM
Firstgenfanatic
Sep 10, 2009 08:02 PM
