Can someone help me identify this wire? Also, fusible link ?
Old Oct 30, 2009 | 07:46 PM
exsanguinate's Avatar
Hi everyone! I recently purchased a 92 D250 and am having a bit of trouble identifying the following brown wire:
I think its for the AC...it is run from under the wiring bundle against the driver front fender close to the firewall and if so connects to a relay or connector as seen above and left of #37 on the below diagram (towards the bottom).
http://dens-site.net/Dodge_CTD/1991....ams/Scan30.jpg Can anyone point me to the connector?
Regarding the fusible link. I need to repair one of the orange links. I found the wire it goes to from the ignition switch but my question is do I splice it to the black or red wire feeding the Y block?
Thanks in advance for the help!!!
Scott
Old Nov 1, 2009 | 12:46 AM
That looks more like the starter relay wire to me.
The black wire feeds all the fuse links.
Old Nov 1, 2009 | 08:54 AM
If it was would it start, cause it does...seems kindof self-explanatory but just wanted to make sure.
Old Nov 1, 2009 | 08:59 AM
Depends on what that yellow butt connector is hooked to. Can you follow that black wire a little further?
Old Nov 1, 2009 | 09:11 AM
Sorry, should have mentioned that...it's hooked to the brown wire and is an aftermarket fusible link wire (which is hooked to nothing). I bought the truck in this condition and I can't tell where this brown wire's home is. The truck runs fine but the AC doesnt blow, the headlights or front turn signals do not work, the power windows and locks do not work. The is a FL that is not connected but I know how to fix that but this brown wire is perplexing me.
Old Nov 1, 2009 | 09:40 AM
Oh, I see - you have the black wire coming out of the butt connector looped around your hand.
Yes, the brown wire most likely feeds the A/C compressor relay. It's the only other brown wire in the area besides the starter relay wire. Originally it would have been on an orange fuse link along with the pink/black ignition switch feed, but it's really not critical. As long as it gets 12 volts with about 20 amps of protection it should be OK.
Old Nov 1, 2009 | 06:56 PM
Thumbs up
You just made me sooooooo happy!!! Thank you a million! Indeed, the pink/black wire from switch is exposed (you can see this in the first picture I posted) and the second orange link on the Y block is indeed blown. So all I need to do is fuse the brown wire and the pink/black wire and splice them both into the big black wire feeding the Y block as seen below?
Thanks a million!!!!!!
Old Nov 1, 2009 | 07:10 PM
That will do just fine.
honobiahunter
Nov 14, 2014 05:45 PM
woodrat
May 20, 2013 09:11 PM
ez_lle71
Dec 9, 2008 09:45 AM
dodgethis91cmns
May 15, 2008 04:13 AM
artieb
Feb 21, 2008 12:38 PM
