can i use this
Old Nov 19, 2008 | 09:49 PM
ol' 93 12 valve's Avatar
Unhappy Confused!! Can i use this?
I put in a new overdrive shift module and od worked the first time, than turned the truck around and headed back to the shop and no od. Checked all the wiring, its good. Have already tried grounding out **** near everything it seams like and cant get overdrive to work. Put in a new trans temp sensor, that didnt fix anything.With that said can i use govenor pressure to bypass the pcm and the overdrive shift module to see if my overdrive works?
thanks
Old Nov 20, 2008 | 05:15 PM
Sure, just follow the writeup in the sticky.
Totallyrad
Jul 19, 2011 07:41 AM
bocuso
27
Jan 18, 2007 12:54 PM
dcwm
Aug 25, 2003 11:47 PM
Got Smoke?
May 27, 2003 09:13 AM
redramnc
Apr 17, 2003 07:56 PM
