Can anyone tell me about this lift pump kit?
Old Jan 28, 2011 | 08:41 AM
Subliminal's Avatar
http://www.dieselautopower.com/produ...ton%20pump.htm
Would something like that still need a regulator? Would it put out too much PSI for the VE?
Old Jan 28, 2011 | 11:00 AM
zack_76401's Avatar
From: Lingleville TX but active duty Air Force all over the world currently
Its the high volume low pressure kit. I ordered it. not the same pump as the one off a 2nd gen that requires regulation.
Old Jan 28, 2011 | 05:35 PM
cougar's Avatar
What pump is it. I put mine together for under $150.
Old Jan 28, 2011 | 07:54 PM
JonathanFleguel's Avatar
i bought this but havent installed it yet looks like everything you need for the install.
Old Jan 28, 2011 | 09:46 PM
ofcmarc's Avatar
Same here. I also went with a big line setup as well when I did it.
Old Jan 28, 2011 | 09:48 PM
JBradley500's Avatar
From: A 5th dimension, beyond that which is known to man.
but when did you do it for 150 bucks? i dont know if you can do it that cheap anymore.
Old Jan 28, 2011 | 10:23 PM
Richie O's Avatar
366 Spring Chicken
Last I knew the cummins shops were selling just the pump for 185 and the case dealers were in the 300's. When I did mine I had just over 100 in everything but I lucked out and got the very next to last old case part number pump. The superceded number is the pricey one.
Old Jan 28, 2011 | 10:44 PM
ofcmarc's Avatar
Last fall.
Old Jan 29, 2011 | 09:12 AM
bgilbert's Avatar
My little concern about the pump pictured in the link above, is the rubber primer 'bellow' on that pump does not look like the ones on the 3936320 CUMMINS low pressure lift pumps I've ever bought or seen...? I question whether it's a genuine Cummins part. I can see the associated parts are but I don't see a Cummins package or label with that pump. Just my two cents .
Old Jan 29, 2011 | 09:21 AM
Richie O's Avatar
366 Spring Chicken
I see what you mean. Its not like mine.
Old Jan 29, 2011 | 10:27 AM
zack_76401's Avatar
Call em and ask him. Ive talked to Jacob a few times, I ordered his kit and hes very forthcoming with answers.
Old Jan 29, 2011 | 10:44 AM
cougar's Avatar
I bought the Delphi equivalent. The rest of the parts from Cummins. My diaphragm pump is crapping out again so for about the same pump price why not upgrade. If the Delphi doesn't prove its self out over time, all I'll need to replace is the pump. At the least it will keep me on the road a while.
tyroneweaver
Jan 4, 2013 09:26 AM
Totallyrad
Jul 19, 2011 07:41 AM
bigfish5
13
Sep 28, 2006 08:01 PM
Czapla44
May 6, 2006 10:59 PM
OH Sick
Dec 10, 2002 04:32 PM
