A/C question
Old Aug 2, 2011 | 07:38 PM
GIT-R-DONE's Avatar
A/C question
The air on my truck does not work. Does the engine computer have anything to do with the A/C ? I want to get it working again, but dont know how this thing works...yet. Can you put the a/c on a seperate switch ? Just needing some info on this subject.
Old Aug 2, 2011 | 07:40 PM
Onemoparnut's Avatar
The ac clutch has power when the key is on but the computer switches the ground to engage the clutch.
Old Aug 2, 2011 | 07:50 PM
GIT-R-DONE's Avatar
So, is it possible to wire or rig this up another way to get it to work ?
Old Aug 2, 2011 | 07:51 PM
maxwellp's Avatar
Is there any refrigerant in it? Also the low psi switch would keep it from running if it is low.
Old Aug 2, 2011 | 07:53 PM
maxwellp's Avatar
Talking
Yes you could run a new ground with it's own switch and by pass the ECM. But you do not know if that is what is stopping it from running.
Old Aug 2, 2011 | 10:24 PM
jimbo486's Avatar
Check your pressures first. Mine hadn't worked for the longest time and I finally got around to figuring it out. I started scratching my head trying to think of where the problem might be. However, it was as simple as just charging the system. I had a leak in one of the lines. I didn't know that until just last month when I had it charged with dye.
mkeanglorldo56
Nov 4, 2007 12:34 PM
Oval Racer
Jan 26, 2007 02:57 PM
8mpg
May 8, 2006 06:37 PM
donhov
Dec 13, 2005 01:48 PM
