A/c Noise--belt Question
Old Jan 28, 2007 | 01:38 PM
BearKiller's Avatar
The wife's truck came home making an awful racket.
On investigation, there were sparks flying from the A/C compressor and the A/C pulley was flopping.
I removed the serpentine belt and replaced it with the spare 67" one that I carry in my truck, thereby eliminating the A/C pump.
Cranked her up, noise gone.
Is the A/C problem something I can rebuild, clutch or bearings, maybe; or, am I going to need a new pump??
Also, what is the correct length/part number serpentine belt for her I/Cooled engine minus the A/C.
Is Dayco #5080640 64 inch the correct one??
If not, what is??
I would like to get back my fifty dollar emergency belt, in case I have trouble.
Thanks.
Old Jan 28, 2007 | 02:49 PM
BearKiller's Avatar
A Couple More Questions
Why is the non-I/C belt an inch longer than the belt for intercooled??
Also, I see NAPA lists a belt # 25080830 for the 91 I/C w A/C for $52.19
Then, they list # 25080830HD heavy duty belt for $62.69
I thought the plain old NAPA belt was pretty heavy-duty; what is so good about this HD belt to be worth the extra ten bucks?? Does anyone run them??
Also, they show a belt tensioner pulley and a belt idler pulley.
I don't see an idler on either of my engines.
Where is this idler??
Thanks.
Old Jan 28, 2007 | 02:51 PM
DAYCO Part # 5080640
GATES Part # K080635
Correct length is 64" - 64 1/4"
I would just get a new A/C compressor.
Old Jan 28, 2007 | 02:52 PM
jcsd250's Avatar
My a/c clutch has been out on my 93 D250 for about a year but since
it's a work truck I gut it out in the heat. Last time I changed the belt
I got a spare Kelly springfield 635K8 for a non a/c truck. (they didn't
have another long belt) The 93 has a diagram for both belt configurations
right in front of the radiator and both should work with no problem.
Let me know if you can redo the clutch on the a/c as the compressor is
pretty steep/ Good luck
My trucks 93 D250 276,000/ 2001 2500 w/65,000
Old Jan 28, 2007 | 02:54 PM
Thanks.
The non-IC trucks used a slightly different water pump.
Don't know on the HD belt, I'm running a basic Dayco myself.
The "idler" is the tensioner pulley. I would never buy one. If the pulley bearings are getting tired, the tensioner pivot point probably has a lot of slop too and before you know it the belt will be walking off. Better just to buy the assembly and be done with it.
Old Jan 29, 2007 | 02:51 PM
bgilbert's Avatar
Hands down best belt to have for all our trucks is the Goodyear Gatorback belt. Can be obtained from Autozone. Just picked one up for my 91.5, was about $28 iirc. (NonAC belt 4080635)
Old Feb 9, 2007 | 09:11 PM
BearKiller's Avatar
Which compressor does the wife's 91 have, C171 or SD709??
Remanufactured NAPA C171 = $277, and SD709 = $451.
New is about $700.
It's her truck; maybe I'll get her a dash-mounted fan, instead.
Thanks.
DodgeDiesel61
Jan 26, 2019 07:45 PM
DodgeDiesel61
0
Jul 28, 2010 11:14 AM
Exekiel69
Oct 28, 2008 07:57 PM
RockcrawlingTJ
Jul 12, 2006 04:02 PM
apwatson50
Mar 3, 2006 06:26 PM
