A/C Compressor PN?
A/C Compressor PN?
I'm looking for a new compressor because mine is locked up. Does anyone know the part number?
How hard is it to change the pully from a V-belt to the serpentine?
Edwin
Edwin
It seems to be so old they are getting hard to find.
Edwin
Edwin would you consider using one of an old engine? Theres a couple being parted out in our classifieds and I think one is off my old truck,( means I know it worked).. just a thought since they are so dern $$$$$$$$$$$
and you have "V" belts????? changing would mean replacing all the pulleys, idler, and maybe some issues with allignning the pulleys as well... But i thought all these trucks used a serpintine belt..
and I find this hard to beleive, BUT, copy and psted from www.chryslerpartsdirect.com when i searched for AC Compressor for an 89 D350 deisel.........
COMPRESSOR, All Models, Diesel, w/o Intercooler 88-93 $231.31 $40.00 $180.42
Yes. I would consider a good used compressor as long as it had the caps on it to prevent moisture contamination. I understand that moisture will ruin them in short order.
Thanks for the link to the new compressor.
Edwin
From what I understand( and that is little!) teh moisture is only an issue if they dotn dry the compressor before charging it. The moisture can cause a "hydraulic lock" in the compressor.. so they would need to put it under a vacum and remove any condensationo prior to charging i tor filling the oil side of it, BUT i am not 100% sure I am correct on that...
WhoCares79
Jun 3, 2008 11:45 AM
Camarogenius
Jun 25, 2007 08:55 PM
Rebuilt one was $3something
