Butthead has redeemed himself
Old Aug 13, 2005 | 11:37 AM
FNJ's Avatar
FNJ
After telling all of you about my snapping the supply side off the fuel sending unit. I was sitting down relaxing , Then it came to me since everything theese days ar pretty much standardised I went to the local salvage yard found a Dodge truck gasser fuel tank and io and behold the tops of the sending units are the same. The gasser unit has an extra vent in it that I just blocked off. I used the pick up and the float assembly from the diesel. Now all is well!!!
Old Aug 13, 2005 | 11:40 AM
That's good info for the next guy. Did the float look like it was made of the same material?
Old Aug 13, 2005 | 02:43 PM
FNJ's Avatar
FNJ
I used the diesel float the pick up tube screen and the lower plastic housing The top part on diesels are red and have asupply side and a return side. Gassers have a supply return and vent witch goes to a canister purge charcoal tank. I just put a vacume cap on the vent side.
Crallscars
16
Jul 25, 2012 04:59 PM
GUMP
May 26, 2008 08:26 PM
Texaschevelle
Apr 2, 2008 03:56 PM
jtalaiver
20
Jun 22, 2007 10:36 AM
FDX
Jan 15, 2007 01:47 PM
