bully dog injectors
Re:bully dog injectors
I did not know Bully dog made nozzles for the first gens.
the nozzles for thr VE pumps pop off at a lower pressure than the nozzles on the second gen trucks. Someone correct me if Im wrong. I believe if you run second gen nozzles in a first gen engine than you may shorten the life of the pump.
If bully dog makes the nozzles for a first gen than give them a try and let us know how they work out. I installed POD nozzles that are suppose to give 60 HP. I am quite sure they do ;D
OK I just went to bully dogs site, they are advertising 50 HP and 100 LB FT of torque for the first gen, They are $499.
Piers sells PODs for $440, Let us know how you like them. I think the first gens are limited by the pumps, so the Bully dogs and PODs are probably the max you can get for a first gen without smoking 100% of the time.
I spoke with Don Becker @ BullyDog about a month ago & even though they aren't listed on their web page they carry +80hp injectors for 1st gens for $435.00 (plus $100.00 core). He did tell me that they will smoke slightly at idle & cruise. I've thought about asking Santa to put a set in my stocking :
as soon as i get them i will inspect them, and post my findings.they was suppose to be here last friday, but as of today still not here , hopefully tomorrow.
well not happy with Bully Dog right now , 1 took 5 days longer to get injectors than was told, 2 got injectors today and their the wrong ones the 2 nd Gen. 12v injectors >
well got my injectors installed tonite, tuned the pump a little, 1 turn in on the full load screw ,test drove it ,and holy cow!!!!!!!!!!!!!!!!!!!!! , first this i noticed was it will bury my 30lb boost gauge in 2nd gear , so will be invest in new boost gauge, before install 24lb. max in o/d , max temp, now @WOT 1250 , this truck will fly now, it goes up through the gears FAST , i really need to dyno this truck now,my older brother has a 03 D-MAX , and well ;D it got smoked tonite.
their the 50 HP injectors, and just puffs a little when you first stoop it , but clears right up when the boost comes up , really don't smoke as bad as the old ones did @WOT
Double stack
0
01-24-2011 10:25 PM
CLeger67
04-07-2008 08:17 AM
chevkiller
16
02-16-2004 01:14 PM
Push Rod
02-08-2003 07:51 PM
