Built something cool for the truck!
Old Nov 25, 2011 | 12:26 PM
bradshaw106's Avatar
With winter rolling in, I started thinking of a high idle device so that my truck will actually warm up... Long story short I built a electrical circuit that over rides my cruise control and with a flick of a switch I can idle my truck up! It's pretty sweet if I don't say so myself
Old Nov 25, 2011 | 01:02 PM
simplysmn's Avatar
Well Share it darn it ?????? sounds like something alot of us could use .
Old Nov 25, 2011 | 03:36 PM
It's still in its developmental stage.... Couple of switches zip tied together under the hood of the truck. Wanted to see if it was even going to work. I also fried my cruise control servo trying to figure out how it worked.. Their happens to be a diode in the servo which is very susceptible to reverse voltage... FYI...
I'm also in the process of adding some protection for the factory cpu
Old Nov 25, 2011 | 06:50 PM
dzl_damon's Avatar
You using a rheostat or something? Or is it a 1-5 VDC kind of thing? Sounds cool!
Old Jan 22, 2012 | 09:05 PM
Any headway on this set-up?
Old Jan 22, 2012 | 10:23 PM
torquefan's Avatar
So this uses the cruise control servo to pull on the throttle linkage and increase idle? If so, sounds great and good for you !! Looking forward to hearing if you get it working.
Old Jan 23, 2012 | 11:38 AM
Sorry for the silence. The project is moving along just slow. Their is a little bit of electronics involved. I'm no engineer so I'm trying to build the best circuit for the job..
Old Jan 23, 2012 | 01:29 PM
apwatson50's Avatar
definitely interested in this. Let us know how you come out!
Old Jan 23, 2012 | 01:44 PM
Ackerdiesel's Avatar
I built a similar device for a kubota pulling tractor. But used a p-pump fuel shutoff solenoid.
Ryan
Old Jan 23, 2012 | 04:01 PM
Something else that is in the works... Is a device that takes the factory tach signal and converts it to a signal that any automotive tach could use! Opens up some more tach options. I built the circuit and in theory it should have worked?? It's kind of hard to drag your oscilloscope to the truck in the middle of winter... I will finish that after the high idle circuit.
Ackerdiesel the cool thing about this device is you can raise or lower the idle to where you want it..
Old Jan 23, 2012 | 04:53 PM
BC847's Avatar
1st Generation Admin
Not to offend anyone but, just so it's been said;
- Don't let this thread turn into something that might cross the line (forum rules), and look like a non-paying vendor taking orders and such.
Thanks folks.
Old Jan 23, 2012 | 05:45 PM
You know there's already people doing this on cumminsforum, there's a whole how-to thread on how to do it and everything.
Old Jan 23, 2012 | 05:46 PM
http://www.cumminsforum.com/forum/89...-write-up.html
Seems pretty straight forward
Old Jan 23, 2012 | 06:57 PM
elephantrider's Avatar
^ thanks for the link. i have over
10k posts on cf, and have never seen that.
Old Jan 23, 2012 | 07:35 PM
gyman98's Avatar
I could be wrong but I think he may be just using the cruise buttons only like a 3rd and 4th gen truck does.
