Brakes building up pressure and not releasing
Old Aug 2, 2018 | 04:49 PM
Shirlack's Avatar
Unhappy Brakes building up pressure and not releasing
We replaced the hydro boost and master cylinder on our 2001 Ram 2500 Diesel. After bleeding the brakes we are having issues with the brakes building up pressure. Have to stop on the side of the road and bleed again. This has happened several times. Any suggestions on why this is happening and how to fix it?
Old Aug 2, 2018 | 06:27 PM
Could be the push rod on the hydro boost is too long and causing the MC to engage?
Old Aug 2, 2018 | 07:30 PM
maybe368's Avatar
Do you have old rubber brake lines in the front? Sometimes these can fail inside the lumen of the line and cause a clapper valve like situation where the calipers cannot return to the relaxed position...Mark
Old Aug 2, 2018 | 09:17 PM
Shirlack's Avatar
That could be, but how could I fix this?
Old Aug 2, 2018 | 10:26 PM
replace the 17 year old brake hoses with new. They don't last forever, and swelling on the inside is a common problem. So is phenolic caliper pistons sticking. Most likely bad hoses.
Old Aug 2, 2018 | 11:34 PM
edwinsmith's Avatar
When I replaced my pads and rotors I compressed the caliper pistons back in. The right one would stick and drag until I replaced the calipers and hoses.
Old Aug 3, 2018 | 05:04 AM
mknittle's Avatar
I would replace all the rubber hoses. used stainless braided on mine. I couldn't say how to adjust the Mopar booster, I went GM Hydro boost before the famous Mopar master cylinder problems started.
Old Aug 3, 2018 | 05:15 AM
mknittle's Avatar
I had a brand new hydraulic hose do that once. Under pressure the fluid would get under the liner and close the hose off. with no pressure the hose looked fine and compressed air went through it one way. took a while to figure that one out. lesson learned blow through hoses both ways
Old Aug 3, 2018 | 05:25 AM
mknittle's Avatar
What booster did you use? With a hydro boost the hoses should be replaced. Hydro boost can put out 2500 PSI where the vacuum booster will put out maybe 1500 PSI.
mtdoragary
Jun 3, 2012 08:18 AM
dodgers
16
Aug 24, 2009 09:14 AM
Yukon Dodge
Jan 4, 2006 08:14 PM
ChrisM55
Jun 2, 2005 10:45 AM
mjfasbender
Nov 1, 2003 08:27 AM
