Brake Issues - Help!
Old Jul 20, 2009 | 08:29 AM
justagoodolboy's Avatar
I've noticed for a while now that my brakes are getting more and more sensitive, meaning it takes just the lightest tap on the brakes to lock the rears up. I've been trying to fix the RWAL for the past few weeks with no luck, but over the weekend noticed something else that might solve everthing.
I was pulling to a light and had to get on the brakes hard because of a car infront of me stopping abruptly, and as I hit the brakes hard, I could feel the peddle pushing back at me. It wasn't a lot of movement, but it was enough to get my attention. After that, I started noticing it doing it even on light braking, but just barely.
What would cause this and could it also be related to why my rears lock up so easily?
Old Jul 20, 2009 | 11:16 AM
Are your rotors warped?? That will cause a pulsing in the pedal and some times if its really bad will make a destinctive sound. like WOOM WOOM WOOM when you ride the brakes.
But this sounds like they're in your back brakes. like maybe your abs is goin bad
Old Jul 20, 2009 | 11:29 AM
92roughstock's Avatar
If your rears are locking up at the slightest provocation, check your drums for oil on them.
Old Jul 20, 2009 | 02:30 PM
No warped rotors and Yes, the back brakes. I don't doubt it could be the ABS as my ABS light is on. I am getting a # 7 code:
7-Electronic control module fuse pellet open, isolation output missing, or valve wiring shorted to ground
I've searched high and low for what an open fuse pellet is, no clue on the isolation output missing, and the wiring at the dumb valve is all good. I'll have my bed off in the next couple of weeks getting a flat bed, and really plan to put some time in on the wiring there incase I've missed something. But could that cause the brakes to lock up and the pulsing in the pedal? I've seen from searching that half the folks on here run with their ABS unplugged.
Did just that, no oil.
Old Jul 20, 2009 | 06:20 PM
14racing's Avatar
We have a truck that does the exact same thing. Does anyone know if you can just unplug the abs box to get rid of the abs?
Old Jul 20, 2009 | 08:10 PM
921stgen's Avatar
Yes unplug it from behind the glove compartment and you'll need fittings to bypass it in the back.
Old Jul 20, 2009 | 09:28 PM
ebteckx's Avatar
bypassing that rwal solved all of my brake problems, from sinking pedal to locking the rears...
Old Jul 21, 2009 | 10:31 AM
What is needed to connect those brake lines and take out the RWAL device on the frame rail? I'd suspect some sort of coupler is available.
Old Jul 23, 2009 | 03:20 PM
IRoss's Avatar
Definitely a proportioning valve is required to fine tune the front/rear bias...othe that that, two short lengths of brake line, either 3/8 or 7/16, I dont remember...the pv requires adjustment whenever a couple of thousand pounds go in the back....
Old Jul 23, 2009 | 04:28 PM
I thought our rides already had a PV on it? Where'd you mount yours?
loomie
Oct 4, 2009 09:39 AM
RyanF
Nov 20, 2008 11:31 PM
JMT
Nov 15, 2008 01:26 PM
Gutterslug
May 8, 2008 11:51 PM
schoust
Dec 10, 2006 06:57 AM
