Brake Issue
Old Aug 13, 2014 | 08:38 PM
WBCACE's Avatar
Brake Issue
Son's boss bought him a 1991 Dodge 1 ton Diesel for a farm work truck. When he picked it up it had almost no brakes at all. I tore it down. Rear brakes where really bad. Replaced both cylinders, seals, shoes. Front were not bad. Master cylinder was leaking a bit so I replaced it also. Bled and adjusted everything. On test drive, pedal on the first push goes almost
all the way to the floor and just barely engages front brakes if you pump the pedal once on the second press everything works great..
Do I still have air in the lines? or is the booster bad also? any advise greatly appreciated
Old Aug 13, 2014 | 09:43 PM
maybe368's Avatar
Welcome to the board! This problem is very common. To answer your questions, yes and yes. Do a search about adjusting and bleeding the rears, there are real good threads on this. You booster being bad will cause a hard pedal, not a soft one, good luck...Mark
Old Aug 14, 2014 | 05:52 AM
bannerd's Avatar
Sounds like you have air in the lines. Best thing to do is loosen the bleeder screw as a helper pumps on the brake pedal for you. If you're a one man show then loosen the brake nipple and wait until you have a nice steady flow. Gravity will help you.
dan123dbl
Feb 13, 2015 05:47 PM
Roperteacher
Nov 25, 2007 10:12 PM
ruquik
Apr 16, 2006 09:37 AM
DDysput
May 5, 2004 07:44 AM
