Brake caliper not releasing?
Old Jun 28, 2017 | 08:03 PM
samiam4's Avatar
You could just rebuild it and use a steel piston. I think my kits and pistons were not $20 total.
no slider pins on a d250, d350. Sliding are just make sure there are not any burs. Rebuild caliper housing usually are beat up.
m
Old Jun 28, 2017 | 08:10 PM
edwinsmith's Avatar
m
I tried rebuilding brake cylinders for drum brakes in the past. They leaked after a couple of months. IMHO getting a new one with a guarantee is worth the extra money. ITOH if you can't find one then rebuilding is an option. The bore has to be polished very well and if there are pits that can't be polished out then it's either re-bore to the next larger size or scrap it.
Old Jun 28, 2017 | 09:08 PM
bigragu's Avatar
m
Samiam- where did you source rebuild kits with steel Pistons for our calipers? I read your comments before about your steel pistons, just curious as to where you bought the parts.
Old Jun 28, 2017 | 09:17 PM
maybe368's Avatar
"By extension, the term lumen is also used to describe the inside space of a cellular component or structure, such as the endoplasmic reticulum."
Ain't medical terms fun! IOW I could have had a problem with my endoplasmic reticulum.
I hate it when that happens...Mark
Old Jun 28, 2017 | 09:36 PM
samiam4's Avatar
You buy the kit separate from pistons. I got my stuff at rock.
m
Old Jun 28, 2017 | 11:47 PM
bigragu's Avatar
m
I was just on Oriley's site. They have Brake Best brand reman's, with steel Pistons in place. Was this a change for the better? I notice the ones for the 4500 lb axles come with steel Pistons, and the lesser rated axles come with either steel or phenolic Pistons.
Not bad a price, at around $30/caliper. Is that the going rate for a reman, and buyer beware, or are reman calipers not bad at all? Calipers 101
Old Jun 29, 2017 | 12:28 PM
samiam4's Avatar
Go steel.
Dodge had a builtin out to replace the pistons with steel if they are sticking.
I didn't see reman with steel pistons when I did mine.
m
mtdoragary
Jun 3, 2012 08:18 AM
dodgers
16
Aug 24, 2009 09:14 AM
Yukon Dodge
Jan 4, 2006 08:14 PM
ChrisM55
Jun 2, 2005 10:45 AM
mjfasbender
Nov 1, 2003 08:27 AM
