borgeson shaft....
Old Feb 4, 2006 | 04:10 PM
Micaiahfied's Avatar
borgeson shaft....
ok i am having a bit of trouble. i can't get the stupid little pin out of the shaft. is there a trick to this that i am missing? i don't want to hit it too hard and hurt the gear box.... please help!
Old Feb 4, 2006 | 04:20 PM
Wedge a piece of wood between the shaft and the frame, then you can hit it as hard as you want. No tricks, but if it doesn't want to come out one way, rotate the steering wheel half a turn and try knocking the pin out the other side.
Old Feb 4, 2006 | 04:21 PM
Underpsi's Avatar
im pretty sure the pin only comes out from one end as it is tappered so maybe your hitting the bigger end trying to force it out of the smaller hole. Take a look and see if this is correct.
good luck
Old Feb 4, 2006 | 04:32 PM
tfarm's Avatar
Yeppers, I just put mine on and I had to rotate to the other side to get it out.
Old Feb 4, 2006 | 07:26 PM
12vchevydually's Avatar
The easy way i do it, is get a air-hammer on it, it will pop right out. It takes all the cuss words out of the Job.
Old Feb 4, 2006 | 09:59 PM
didn't have time to update earlier. i got it out.... took a while to find the correct size "punch" that would not flare the end but give me enough whack at it. anyways, it's all swapped out and man, there is a heck of a difference. no more slop!
Old Feb 4, 2006 | 10:27 PM
Glad you got it worked out.
furious70
Mar 20, 2005 11:19 AM
jimsdsl
Oct 25, 2004 11:14 PM
furious70
Nov 17, 2003 04:25 PM
Raspy
Oct 31, 2003 01:17 PM
furious70
Sep 6, 2003 07:18 PM
