boost prob
boost prob
ok guys my ive been reading the forums alot and everyone boost levels are alot higher than my truck has ever got ive got a htt stage three turbo high flow intake straight4in exhaust 16cm exhaust housing and from what ive been told buy the old owner of the truck 25 hp injectors my truck with my foot to the floor gets at its max 25psi and thats on a good day ive checked my innercooler hoses and they seem fine any help would be very cool
Are you seeing any smoke under full load? If not, and you're sure there are no boost leaks, then it sounds like it's time for more fuel...if you want more boost. Really, 25psi is about the sweet spot for that turbo anyway.
if you have a pyro,... to keep a i on the heat then i would say the you need more FUEL!
time to turn turn the pump up!
Boost will come down as you approach the governor. An original stock (read-old and tired) governor spring will only pour all the coals to about 2100 rpms before it starts defueling. Also, if your lift pump is weak, the injection pump will start to starve at high rpm/load, which will also cause boost to fall off.
If the small follower pin that rides on the larger fuel pin is sticking, you may not be getting fuel consistantly. I fixed mine and promptly pegged my 35 PSI boost gauge on the first run out.
What can you use to spray into that pin to keep it from sticking if that's the problem?
It took a while to get the guts uo to drive the shaft out, but there's a ball bearing on each side of the shaft that's used to retain it, so it's not as difficult once you get things moving.
You might get lucky and be able to lube the pin from inside the AFC housing, otherwise you get to dig a little deeper.
hey man thanks for the info ill try that as i remember the afc pin was a pain to get out took a few pulls to get it out it just didnt pop out i cleaned everything installed the afc pin back in and had no boost at all so i putt the peddal to the floor and boost jumped back up scared the crap out of me
dropped2500
Feb 7, 2008 07:14 PM
bigbaddiesel
Apr 12, 2003 11:24 AM
