whats the prob w/ pulling in o/d
Old Apr 4, 2003 | 10:17 PM
bigbaddiesel's Avatar
If the tranny temp stays low and egts are low, is there any harm in pulling a load in od? Just a 8' camper and 17' boat.
Old Apr 5, 2003 | 06:03 AM
Dieseldude4x4's Avatar
Re:whats the prob w/ pulling in o/d
I pulled a 16 foot tandem axle trailer with four four wheelers and a dirt bike up and down the mountains through WV and Pa with no problems with my 95. When it came up against a hill and the rpms dropped enough, it would kick down out of overdrive and go on. Never had a problem.
Old Apr 5, 2003 | 06:09 AM
pappyman's Avatar
I pull a trailer 60% of the time....and always in OD...unless the engine is in a lug....or tranny temp gets high....I use a OD lockup switch at times if my tranny starts to hunt (in and out of OD lockup)....normaly my tranny temp pulling is 150-170*
Old Apr 6, 2003 | 10:59 PM
SmokinGreenMonster's Avatar
I allways pull in OD at 75mph, 4500lb trailor 18ft bass boat no problem. Good pulling anything. HEE HEE.
Old Apr 6, 2003 | 11:06 PM
tmiller24's Avatar
I was told by a trans expert that towing in OD is OK as long the RPM's stay up. Rpm is what makes the fluid pump in the trans do it's part and we all know what happens without lube.<br><br> Tony
Old Apr 8, 2003 | 10:50 AM
thats good to hear. I heard not to do that. I guess it was only a truck salesman that told me that. I much more believe what I find out from all you guys on DTR. Thanks for the responses.
Old Apr 8, 2003 | 09:52 PM
Srigs's Avatar
DONT ever believe a truck sales person! <br><br>Read the manual and it says go ahead and tow in OD. I did this afternoon with my rig below.
Old Apr 8, 2003 | 10:05 PM
Ray,IN's Avatar
Towing is OD is not the problem. Allowing the AT to &quot;hunt&quot; for the proper gear is the problem. This repeated shifting into and out of OD creates a tremendous amount of heat very quickly. Upon the AT rebuild, under warranty, the Tech emphaticly stated to never use OD under 55mph when towing in hilly terrian to avoid this condition of the AT hunting the proper gear.
Old Apr 8, 2003 | 10:09 PM
pappyman's Avatar
Or you can baby you rig to save your engine and tranny and never work the truck.....wait a second are we talking about a CTD or a Powerjoke...too many CTD owners never work these trucks fearing they mite break it &gt;
Old Apr 10, 2003 | 06:20 AM
Smokee's Avatar
What Pappyman said!!! Use that torque ;D
Old Apr 11, 2003 | 11:27 AM
SjLingenfelter's Avatar
I have a PSD for now until the summer. But It has exhaust TC and 130hp chip and pulling a 2000lb trailer with 2 4wheelers and a John Deere 6x4 Gator. And my tranny never gets really hot.Even when I run it in OD for the some of the hills. I dont really need to cause I cruise right at 2200-2300 and thats where all my power is. I dont baby it at all unless its cold but thats only until the motor warms up.
SD03
Old Apr 11, 2003 | 07:19 PM
98rammer's Avatar
i baby mine in most other ways...warming up/idling in neutral, taking it easy when it's cold, keep the converter clutch from slipping, etc.....but otherwise it sees daily WOT shifts constantly 8)
Old Apr 12, 2003 | 11:24 AM
emjay's Avatar
Ray hit the nail on the head. it's the constant shifting that's bad. The tranny fluid in my rig runs about 125 deg F because the TCC stays locked above 30 MPH.
mullercarl
Competition / Pulls / OffRoad
45
Mar 19, 2007 10:10 AM
aaronisbad
Feb 15, 2004 10:42 PM
psalm69
28
Jan 28, 2004 11:56 PM
Superduty12v
Dec 2, 2003 11:55 AM
xzlram
Jun 22, 2003 11:34 PM
