boost/intercoolers
A 16cm housing will get you 2-3psi more than a 18.5 housing and 5-6psi than a 21cm housing.
Its easy to get 30+ psi out of a 89-91.4, 1st gen engine with stock inj's. Its a little harder but very possible to get 30+ psi out of a 91.5-93, 1st gen with stock inj's as long as the engine and pump is healthy.
whoa whoa whoa....what book says these IC's loose 4-5psi
I've not taken any measurements to verify the statement. But we all know that elbows, length of piping, etc contribute to pressure losses in fluid transfer depending upon a lot of factors. I think that's more the point.
I have no intention of starting a "boost war".
Jay
I bought my governor spring at a place called Delco Diesel out of Ok. It was $16 that included shipping and tax. Yes it is worth it. The governor spring works good especially if you get an Old Smokey power pin.
My stock 92 has a 16 CM housing and the fuel screw in some and it gets about 23 PSI boost. Im at 4600 elevation.
Good luck
Good luck
I can get 29-30 at wot, but also have pods, 16cm housing and 4" exhaust, and egt's are only about 1150* at wot, with the 18.5 cm housing, I could get 1450* easy and about 24-26 psi boost.
Wouldn' the boost loss across the IC be more closely tied to the cooling of the boost air and not a true "loss" as in leakage or whatever.... or did I just take a seniors nap here....
pb..
pb..
It would be very interesting to run a pre & post cooler pressure and temperature guages . . .
