Big issues
Old Nov 20, 2010 | 06:55 AM
chevelleriley's Avatar
Exclamation Big issues
so last night i was driving my truck round and noticed that my spedo wasnt working anymore, then it would work for awhile until i went to open my window and noticed that wen i press the button to put it down it would turn off the speedo, same thing if i press the lock button and if i change the heat selection. the only thing i can think of is a bad interior ground, anybody have any input cause i gota get this fixed, thank you
Old Nov 20, 2010 | 08:22 AM
towriggity's Avatar
Run a ground from your negative terminal on the battery to the body of the truck, fixed all quirkiness on my truck, good luck
Jake
Old Nov 20, 2010 | 07:46 PM
u.s mma's Avatar
yah, i had a bad body ground, causes all kind of ghosts.
Old Nov 20, 2010 | 08:01 PM
PapeCAT's Avatar
yup x3. A bad body ground can be induced easily as well if you ground a wrench accidentally from the hot lead to the fender.
JSCumms2000
20
May 6, 2007 02:14 PM
Mexstan
Sep 16, 2006 05:29 PM
boiler-rat
Jan 16, 2006 03:11 PM
Dieseldude4x4
Oct 17, 2004 11:07 PM
Shaders 24v
Aug 11, 2003 10:18 AM
