Starter Trouble?
Old Nov 19, 2010 | 12:35 AM
broncobilly's Avatar
Starter Trouble?
All,
My 93 W250 with A518 auto is having starter trouble. A year ago; I replaced the brushes with Larry B's kit. The starter worked well for about a year. Now with the drop in temp's here in northern IL, the starter is acting up.
The starter will crank, but not fast enough to fire the engine. The battery is an Optima Red Top, which is 4 years old, but has always been on a trickle charger, and is holding it's charge. With a little over 200,000 miles on the odometer, I suspect the starter is finally going? If I tap it with a rubber mallet, sometimes that helps, and the truck will start. What's my best option for a rebuilt starter - NAPA, Advanced Auto etc? Or; is a new starter advised? Thanks in advance!
Old Nov 19, 2010 | 12:40 AM
MrExtreme's Avatar
I have done a lot of electrical mods and have 3 Optima Yellow Tops and my starter started dragging, I cleaned all the battery connections and it starts just fine now, while Optimas don't show the white flaky corrosion of a normal battery the connections can still get dirty. Give that a try.
Old Nov 19, 2010 | 08:23 AM
maybe368's Avatar
Originally Posted by broncobilly
All,
I try to have the originals re-manufactured. There is an outfit here in Phoenix that does great work and a starter is around 60 bucks, with new armature. I don't know how close you are to a big city ,but there are some there in Il. Ithink). ...Mark
Old Nov 20, 2010 | 11:53 PM
MrExtreme and Mark,
Thanks for the info! I will try cleaning the connections and see if that helps. That could be the problem; as when the temps were warmer here in IL, the starter had no problems. It could be with corrosion on the battery cables, combined with the grid heaters kicking in (with the colder weather), that the combined effect is causing starter drag? Mark, I will see if any place here around Chicago offers rebuilding of the starter.
Old Nov 21, 2010 | 05:06 AM
jogl's Avatar
X2 what Mark said. I have had very good luck getting starters and alternators rebuilt at the local shops. They are listed under "Automobile Electrical Service" in our yellow pages.
JP.
Old Nov 21, 2010 | 06:40 AM
dzl_damon's Avatar
I always start with cleaning connections.
It's free, it solves the problem a lot of the times, and it should be done even if it's not the problem.
FMB
Nov 14, 2010 09:09 PM
12valvesmoke
Jun 12, 2009 09:46 AM
buckman361
Nov 13, 2008 09:54 AM
Paradise Racing
Jan 18, 2005 09:08 AM
ts
Dec 10, 2002 11:35 PM
