Big Cummins Rotary Pump
Yup. Back when Diesel Power Mag was at the Wilshire Blvd address, the backup generator for the building was an 1150 cid KTTA Cummins. Had a big rotary pump. Won't work on a 6bt or so I was told after I saw it and asked a few people
How is your 14mm pump holding up? Are you going to run against the 2x4 Ford in the mag?
It's holding up fine...I have about 600 miles on it and 10 dyno pulls....still doing great, although I think a lot of that has to do with having a 3200 spring and 30 psi of inlet pressure.
The pump on the KTA and NTC engines is not a rotary pump the system is called P/T = Pressure Timed all the pump dose is supply pressure to the injectors and the cam activates the injectors its nick name was Part/Time ken
Yup. We cant use it for the same reason we can't put a "real" jake brake on the 5.9 - no injector lobes on the cam.
Exactly, I've got 3 KTA50 Cummins GenSets with 1050kw 600v gens and they are the hardest things to tune. I run them all with Woodward 2301D governors and trying to build the program to run those pressure timed pumps is a headache. I finaly have a generic tune I load and tweek from there, but I'd much rather have a 3506 Cat in there place. The Cats respond to load instantly and have way less problems than the Cummins crap we bought. I'm sure in a supply boat they are fine, but on an oil rig as a genset they seem to suck!
The Cats we use mostly are 3512's, which are V-12's, but we do have 2 3508's and they have plenty of power to run a top drive so I'm looking for a few of them. So far all 3 cummins have been in for total overhaul at 5-8k hours, really not the downtime you want on an oil rig. Plus when the rigs go down I dont sleep!
You still have the murphy engine controls? The big red rig setups were intended not have much fluctuating in load. They need a modern avr setup with under frequency roll off setting for what ya'll are doing. Would cure all the problems we're seeing on these units. What company are you working for? or pm me.
