Best system system
Old Mar 5, 2025 | 08:22 PM
Firstgenforever's Avatar
Best suspension system
I won’t be getting some for awhile but trying to figure out what I want been doing a lot of reading and this is what I have found
1. kelderman is the best of the best
2 caril coil over really good
3 a good set of springs with bilistien shocks
4 4 link bag suspension
or what about skyjacker soft ride springs will they affect my towing I do a lot of towing with this truck I would like to keep the same or obtain a higher weight rating
Old Mar 5, 2025 | 11:03 PM
u2slow's Avatar
I prefer a more stock-like spring, and accomplish any lift by moving the hangers.
If you do move/change hangers, recommend longer leafs for better ride.
Old Mar 6, 2025 | 08:36 AM
cougar's Avatar
#3. The guys at Alcan Spring set me up with a great set of springs. As for shocks, I went with Monroe coil overs in the front and magnums in the rear. Did it give me a "softer ride"? No. But it did help with towing stability without decreasing my weight capacity. You can't beat leaf springs for a work truck.
Old Mar 6, 2025 | 10:08 AM
I have posted several threads on trucks I have lifted.
I like SkyJackers springs for what you get for what it costs.
You will not be legally raising your weight carrying capacity by adding different suspension / leaf springs to your truck.
Old Mar 6, 2025 | 04:36 PM
u2slow's Avatar
1ton leafs or aftermarket stuff from an upfitted wrecker or dump truck (also "1ton'") have served me well.
Very true, but that tends to slide by the wayside with a personal-use vehicle. I set (license) my w250's gvw at 12k# and do what it takes to make the truck look comfortable with 2tons payload.
4CEFED
Mar 5, 2011 05:21 PM
Bowser50
Off Road / 4x4
Nov 4, 2008 09:53 AM
whistling turbo
Oct 20, 2007 03:04 AM
04 SO CA
Jun 7, 2007 04:48 PM
swdiesel
Apr 27, 2006 07:23 PM
