battery cables
Old Jun 16, 2019 | 08:13 PM
willy wagon's Avatar
battery cables
just wandering where anyone that has replaced battery cables is getting them?
Old Jun 16, 2019 | 10:37 PM
edwinsmith's Avatar
AFAIK My cables are original. They are 4/0 gauge and except for the battery ends which had been replaced with those cheap clamp on ends. I got some crimp on eyelet ends and used military style terminals on the battery.
Find a welding supply and get some 4/0 cable and have them put the ends on if possible. Then use the military style terminals on the battery. You'll be happy you did.
Edwin
Old Jun 16, 2019 | 11:31 PM
maybe368's Avatar
Like Edwin said, any good welding shop can make them, although mine are made of double 00 welding cable. I once paid over 100 dollars at the dealer for the negative only...Mark
Old Jun 17, 2019 | 01:29 AM
GabrielMacht's Avatar
For best battery tenders click here
Hi!
Just like Edwin said, get it made by a good industrial electrical shop. It will cost considerably less, and will be as good (if not better) than OEM ones. Just make sure you have a high-quality battery terminals, and that they are securely fitted to the cable.
Regards.
Old Jul 9, 2019 | 03:32 PM
jc1390's Avatar
I recently replaced my cables with later model Dodge Ram cables. I believe the Positive line is from an early third gen and the Neagtive line is from a later third gen. Worked excellent. Ill have to take some pictures one day.
Old Jul 9, 2019 | 03:42 PM
BHD's Avatar
BHD
Any good Napa or heavy truck parts store can usually make whatever size you want with parts off the shelf. Mine are 2/0 with stud style ends to run Group 31S batteries. You're probably looking at 50 to 80 bucks for both positive and negative cables.
Old Jul 9, 2019 | 03:55 PM
u2slow's Avatar
^ I do this. #2/0 works too.
The terminals I either get from a battery shop or online. Hammer style crimper with copper paste. Heatshrink over top; or tightly taped if I run out. The cable I wait till Princess Auto has it on sale (Harbor Freight may do the same.)
Old Jul 10, 2019 | 10:18 AM
cougar's Avatar
I had mine made by a local wire company to my specifications. Napa here couldn't make them.
Old Jul 19, 2019 | 04:28 PM
Jim5870's Avatar
I repaired mine by chopping off the original end and using a solder on battery terminal. Better than original.
Old Jul 21, 2019 | 10:29 AM
Denis's Avatar
I got mine from this place.
https://www.custombatterycables.com/...500-1989-1993/
Old Jul 22, 2019 | 10:11 AM
cougar's Avatar
Originally Posted by Denis
I looked at those and decided, nah. I don't want to keep fighting corrosion where the bolt goes through. I have enough problem with that on my 2nd gen.
taildragger
38
Dec 19, 2006 09:49 AM
Hoss15
Oct 27, 2005 11:06 AM
leprechaun
Sep 14, 2005 08:20 PM
banzaitoyota
Sep 29, 2003 04:36 PM
ggolub
Jul 5, 2003 06:16 AM
