Bad steering box??
Old Sep 12, 2012 | 06:39 PM
Farmboy12357's Avatar
Bad steering box??
What are the symptoms that you need to replace your steering box? My steering is pretty loose and it is starting to wander where I can't have complete control over the steering when I'm driving. I've jacked the front end up and had someone turn the wheel and can't see where anything is loose/worn out/ or needs replaced....
Old Sep 12, 2012 | 07:27 PM
BILTIT's Avatar
Might need to be adjusted.
http://www.off-road.com/jeep/tech/po...ent-20047.html
Old Sep 12, 2012 | 07:45 PM
simplysmn's Avatar
First I would check to see if box is Loose ? then check steering shaft just give everything a good hard jerk and then I would look deeper into box willing to bet you may have a cracked steering box plate or something else not seen the first time
Old Sep 12, 2012 | 10:33 PM
I tried adjusting the box but I couldn't get the nut loose and didn't want to hit it to hard and move the allen screw when i loosened the nut so I chickened out for now but will try again tomorrow
Old Sep 12, 2012 | 11:35 PM
post a video of the "under the fender but above the tire" shot on youboob. Make sure you can see the shaft / gear turning while the wheels more or not. Maybe we can do this long distance....
Reality is you should be able to see play in the gear / shaft / gear mount or other while slowly moving the steering wheel.
Old Sep 13, 2012 | 03:26 AM
Bogie's Avatar
I would not turn that adjuster just yet, start with the bearing preload. See this TSB if needed a rebuild is fairly easy RCC Rebuild I want with a AGR box and have been very happy with it.
Old Sep 13, 2012 | 10:44 PM
I can get a reman steering box for $152 through my work from O'reillys or Kaps Auto Parts for 116 plus shipping...How do those prices sounds?
Old Sep 13, 2012 | 10:59 PM
simplysmn's Avatar
Had a Napa box and it was Fine .
65fury
25
Apr 6, 2007 08:16 AM
04ctd
Oct 5, 2006 08:27 PM
Buckshotram
Jan 9, 2006 09:27 AM
C Pierce
Mar 21, 2005 08:41 AM
Eskimo
Aug 9, 2004 03:05 PM
