AZ Skrap Truck
I haven't posted in years. It looks like the suspension upgrades were in 2020. Over the last year+ I've worked on the truck a lot as I prepare to pull my camper and travel.
Engine
Drivetrain
I'm likely forgetting something. I'll try to add pictures later.
Up next is some much needed electrical repairs and updates.
Engine
- Front main
- KDP
- Water pump
- Fluidampr
- Oil pan gasket
- Rear main
- Poly Bushing Engine mounts
- Optitorque torque master Head studs
- PDD 60lb valve springs
- BHAF
- Infinite Performance HX35 60/60/12
- DPS Exhaust manifold
- Mel's stainless exhaust
- HVLP lift pump
- Fuel heater delete
- Ratman Delivery valves
- Ratman Fuel pin
- 3200 spring
- Infinite Performance reworked stock injectors
Drivetrain
- Loganbuilt VE King trans rebuild (including flex plate and converter)
- Transmission fluid-to-fluid delete (Yes, I know this is controversial)
- Poly Bushing trans mount bushings
- Resealed transfer case (every gasket and seal)
- Both driveshafts rebalanced with all joints and carrier bearing replaced
- New bearings, races and seals in all four hubs
- Drum brake overhaul
- Rear shocks
- Brake hoses
- Heater box cleanout
- Tach, Pyro, Boost, and Trans temp gauges
- 2nd gen shift lever
- Window motor drive rebuild
It seems to go in phases for me depending on other hobbies or home maintenance. I'm enjoying the diesel work right now. Plus, I want the truck working well so I can depend on it for long road trips.
Yeah, that's the adulting part of life! At least you're in AZ, nice and rust free. I spent 3 years in Yuma, would not recommend!
Currently I'm visiting family in Indiana.
fordassassin
Jun 8, 2008 03:54 PM
Jezzhuntin
Jul 10, 2007 01:46 PM
Bigduallywheels
54
Feb 23, 2007 09:43 PM
ocsurf16
Jul 2, 2006 06:44 PM
