axle ratio?
Old Dec 14, 2008 | 01:52 PM
jj3500's Avatar
axle ratio?
How do i find out this information. The paper tag under the hood is too faded and beat up. Can not read it. No metal tabs on diffs either. 89 one ton C&C. automatic.
thanks
Old Dec 14, 2008 | 03:14 PM
Richie O's Avatar
366 Spring Chicken
89's with the 727 auto should be the 3.07 ratio.
Old Dec 14, 2008 | 04:55 PM
93-12Smoke's Avatar
Should be able to run the vin through a vin identifier site.
Old Dec 14, 2008 | 06:31 PM
Like Richie O said, with a 727 the only gear available was 3.07's. The only exception to this is the military aircraft tugs.
Old Dec 14, 2008 | 07:24 PM
3.07 gears, no doubt about it.
Old Dec 22, 2008 | 05:10 PM
R C Cola's Avatar
Axle ratio
For Certain method. Jack up the rear. With a piece of chalk or crayon make a nice big mark on the side of the tire pointing down and another on the drive shaft on bottom or side so you can see it easily. Next rotate the tire slowly around counting the turns. Exactly 3 turns plus .07 gives you 3.07, or 4 full turns plus .11 gives you 4.11 etc. etc. If you need extra visual motivation have your girl friend wear her bikini while turning the wheel for you.
BubbleChaser
May 2, 2004 04:14 PM
Hitchhiker
Nov 13, 2003 02:04 PM
mthomas
Nov 6, 2003 10:53 AM
kerrdog
Apr 1, 2003 10:06 AM
Hummin Cummins
Jan 27, 2003 08:31 PM
