axle jam nut
axle jam nut
do they make a special socket to get the jam nut off? I tried an assortment of punches and chisels to get it lose but it is just to tight. I have a spindle socket for a D44 but it is to small. the notches line up but not wide enough. These are normal threads correct? not left handed??
anyone have any other suggestions or tips?
thanks
thanks
It's a 2-9/16'' nut and you need a thin-wall axle nut socket. Usually, you can get them loose with a hammer and punch. They are standard threads. There should be a little retainer than presses into the slot on the spindle--did you remove that?
thats the rear right^^^? i am working on the front
I got my '92 d60 front apart with my old trusty broken and slightly bent skrewdriver. Make sure the tab is not bent up in any of the slots. They make a special socket. There was a thread on it a couple of weeks ago.
I believe this is the part you are looking for.
http://www.napaonline.com/masterpage...ock+Nut+Socket
the circled part is what i can't get off.
this is where it is when installed in the hub
the bugger is really on there. i bent a screw driver to get a better angle on it but i ended up busting it. don't know what else to do. i am going to try the other side and see if i have any better luck.
If you were a little closer I would let you use mine. I got mine from the local auto parts store, can't remember if it was Advanced or National. One of them should have that socket in stock to either buy or rent.
Please Put This In The Sticky!!!!
I wish they would put this info in the sticky. I wrestled for a week to get the right socket, umpteen trips at $4/ gal had me fried. The proper spindle nut socket is CTA tools#4165. The socket for a dana44 will NOT work, as the one pictured above will not either. The Tool is a round socket, double thickness where it fits over the nut with 4 pieces of square stock protrudig into it at 12 3 6 and 9 o'clock. The Lisle tool combo socket is real close but after $35 and modifying it, it did not work. That was part #27400---No good. I tried others and returned also. PITA. Socket description must clearly state it fits 4500# dodge front axle. The CTA model works perfect, was only $20. and is avail at Bumper to Bumper stores.
I dont know why, but my dana60 front had the 2 9/16 nuts on the front. Made me cranky cause I have dana 44 and 60 normal nut sockets. (the weird lookin things) Dontcha love trips to the part store for a tool after the trucks all ripped apart?
What year is your front axle, and was just the outer nut that or both of them?
Try this, these are all I had to try to finally find that #4165 is the proper one even though it is not the one that says it fits a dodge. Good luck, put this in the sticky!!!!.
http://www.ctatools.com/catalogs/200...BrakeWheel.PDF
Just cut and paste this in the search bar...If you can not click on it.
my 2-9/16'' works up front on mine.
