Aux fuse blocks, Need input
Old Nov 14, 2008 | 08:37 PM
DNRCustoms's Avatar
I am looking to get a aux fuse block to aid in power distribution... But I am not the most electrical savy if you get my drift... I am looking at getting one from painless, do you think I should get one with all ignition hott circuts, or like 4 ign hott, and 3 constant hott... Here is a link to the one i'm looking at getting.. looking for this to power aux guages, trans cooler, trans lock up switch and od switch...And maybe more, but those are the necessities for now... Any input greatly appreciated...
http://www.painlessperformance.com/w...archAll=Trucks
Old Nov 14, 2008 | 09:33 PM
Alwaysworking's Avatar
alwaysonDTR
i would want a some hot all the time spots for say a cigarrett lighter to charge my phone without leaveing my keys in the truck, one for switchable lights, but thats just me, there probally more.
Old Nov 14, 2008 | 09:38 PM
DNRCustoms's Avatar
Ya..thats what I'm thinking... Just not sure if 7 circuts will be enough... I would like to just do it once... looks like tha tone gives me 3 constant hott, 4 ignition hott... The thing is, it will never be enough im sure...
Old Nov 14, 2008 | 10:45 PM
BearKiller's Avatar
Those Painless units are WAY overpriced and not nearly as painless to install as they would lead you to believe.
A smart man like you can do much better for a lot less.
I have a relay-triggered key-hot panel and a bejillion always-hot auxilliary fuse-blocks scattered around my truck; if I can do it, I have no doubt that you can.
I recently added a brain-box to control the multi-tude of turn-signals on my truck, each direction dual-relay triggered and every seperate bulb fused, such that a short anywhere only loses the one light.
Old Nov 14, 2008 | 11:48 PM
BearKiller's Avatar
These are my favorite type of fuse-block :
http://www.delcity.net/delcity/servl...d=10960&page=1
Reasons being :
There is one big 8AWG feed-wire that is already pre-wired to all of the fuses.
Each fuse has its own SCREW-TERMINAL, such that a lot of tedious wiring/soldering is avoided.
SCREW-TERMINALs with RING-TERMINALs on the wire-ends are the most positive means of good electrical contact, with the most surface area contact.
Since the fuses each have their own screw-terminal, the fuses are not "hard-wired" to the accessories, making any future alterations easily accomplished with only a screw-driver.
Lately, I try to use as many screw-terminal blocks in my circuits as possible, eliminating many hard-wired circuits that are so hard to trouble-shoot at a later time.
For example:
I ran a wire from the marker-light switch to a terminal-block, such that switch-ON makes all the screws HOT; then, each seperate group of marker-lights has it's own wire that gets attached to this terminal-block.
Such as:
Front markers--rear markers--head-rack markers--left running-board markers--left flat-bed markers--etc.--etc.
I can add or remove light circuits at the terminal block, without the need to cut wires.
Old Nov 15, 2008 | 07:39 AM
Trebor's Avatar
Good find! Good price! Bookmarked for future use.
Old Nov 15, 2008 | 07:40 AM
DNRCustoms's Avatar
Reasons being :
For example:
Such as:
That is much better, I didn't want all those wires that comes with the painless one.... plus it was only rated for 30amp...Thanks for the lead!!
Old Nov 15, 2008 | 04:36 PM
archer39's Avatar
Thanks for the link, i just ordered 2 of them and 100ft of wire loom. My winter project, redo all the previous owners wiring
i have been looking for something like that all i could ever find was what DNRcustoms had posted.
Old Nov 16, 2008 | 12:31 PM
rbrettctd's Avatar
I picked up a fuse block from oreillys and wired it ignition on hot and stuck it behind the glove box. 6 or 8 circuits on this one. Gonna add another alltime hot when I need more.
98silver12v
Jun 24, 2009 11:15 PM
Katmandu
Jan 16, 2006 08:30 AM
SilverDiesel
Dec 7, 2003 07:02 PM
