Automatic trans, O/D Question ???
Old Oct 2, 2004 | 01:59 PM
canucktrucks's Avatar
Question Automatic trans, O/D Question ???
I 'm just curious if there is any way to change or adjust the speed or RPM that the trans shifts into O/D at ??? I have yet another Dodge Diesel left in the stable, and I dont really like the way it goes into O/D...... I think it needs to shift into Over drive sooner, it would be perfect if you were towing heavy with it all the time but thats NOT the case, I just want to adjust it a little bit sooner ???? Please help............Canucktrucks
Old Oct 2, 2004 | 08:53 PM
Tommy93w350's Avatar
I think you might be able to adjust the throttle postioning sensor. I don't know for sure but it might be a start.
Old Oct 2, 2004 | 09:59 PM
darloa's Avatar
Try http://www.piersdiesel.com/Tech1GTPS.htm. It explains how to adjust the TPS to chand the shift point. Hope this helps. Good luck, Darl
Old Oct 3, 2004 | 11:17 AM
apache's Avatar
Ive messed with my 93s. And I cant quite figure it out. under heavy throttle its adjusted so it wont hit OD till 55 or so,which is great when loaded, but if your just puttin around easy it will still hit OD at 35 mph. Also as I know temp will affect it, headin in when its cold it will stay in 3rd even at 55 or 60 for several miles.
Old Oct 3, 2004 | 06:44 PM
Dan Brooks's Avatar
I have my TPS set to .7 volts and that seems to work best on my truck and driving style.
apache - The trans isn't supposed to shift into OD when it's under a certain temp (can't remember spec right now). One of the senders on the intake controls OD operation when cold, and the sender on the trans line kicks it out of OD when it hits 270*...which is way too late, IMHO.
Old Oct 3, 2004 | 10:03 PM
Bushy's Avatar
Patron Saint of 1st gens
Here ya go... an oldy and a goodie..
TPS ADJUSTMENT....
The TPS has a 3 wire connector on the top, engine side.
The center wire is orange (with blue stripe?) I believe.
Under the TPS body, is a shaft that protrudes downward. The shaft has a
hex head end that fits into a 'female' hex socket.
This shaft is lightly spring loaded. When the hex headed bolt end is pulled
upwards on removal the head/shaft may 'snap rotate' an 1/8 turn or so,
so watch it as it comes out since it needs to go back in the same position.
( Removal of the TPS happens when you want to access the inside
of the AFC housing to adjust the diaphram or starwheel.)
Just be sure to take a preliminary reading off the TPS before you remove it if
that is part of the job your doing. (Like when taking the top off the injection pump)
Right near the top of the shaft were it first comes out of the TPS body, are two "flats"
were you put your open end wrench to adjust.
You'll need a DC Voltmeter, as safety pin, or paperclip with the end slightly sharpened and,
a combo wrench. I think its a 10mm.
Slip the safety pin or paperclip into the 'socket' part were the center wire comes out of
until it makes connection with the metal jacket inside.
Connect the "+" probe of your DCVM to this.
Connect the "-" probe of your voltmeter to the "-" terminal on the battery
(it's just convenient)
Turn on the Ign. key (do not start truck) and check the "at rest voltage".
It should range between .6 VDC and 1.20 VDC. (make a note of the reading for reference.)
Next, slowly cycle the throttle smoothly to WOT then back to "at rest" and watch the meter.
It (the needle) should increase smoothly up and down with no jumps or spasms/twitching.
If it does, the TPS is still working ok, if not you've got a dirty one or its failing.
I believe the total increase (above "at rest voltage") should be about 2.75 VDC.
Now, you need to go back to that shaft coming out from under the TPS.
Use the wrench to adjust the voltage SLIGHTLY!
Start with + .2 VDC to begin with (to delay 3-4 shift a bit) OR -.20vdc
(to have 3-4 happen earlier.)
Increasing voltage will cause the 3-4 shift to happen LATER.
Decreasing voltage causes the shift to happen sooner.
I found that there was a point were the shift happened later, but also tended
to cause the downshift (4-3) to be a bit touchy too, so you need to adjust a BIT and drive each time.
When you do your test drive try to use the same throttle pressure/RPM for each,
that way you'll know what effect you had with the adjustment.
I did a "medium" throttle (1600 RPM) and a WOT test each time.
Before I had the tranny work done mine ran just fine at about .7 VDC ~ .8 VDC "at rest".
Last thing to ckeck... make sure that your TV cable returns properly.
The lever on the trans. case should move all the way forward with the truck off/idle.
I had to add a "universal" throttle spring to be sure that happened, otherwise the line pressure(s)
at idle are already increased above what they are supposed to be at idle and you may have harsh
engagement when shifting from "P" or "N" into "D" or "R".
In the event you need to remove the top TPS body itself remove the two screws holding it down.
Carefully lift it up and note that underneath there is a plastic slot and key type indexing.
Once the TPS body is off you can turn it over and spray electrical contact cleaner into it,
working it back and forth. The use some gentle compressed air to dry out the spray cleaner
(it evaporates pretty quickly). Once done, re-install it and try the re-set procedure again and
watch your dcv meter for smooth movement.
You can find some good pics of this thing in my 'Readers Rigs" gallery under VE Gallery label.
Hope this helps you if you need to work on the dreaded TPS.
Bob. aka: BushWakr
Old Oct 4, 2004 | 10:14 AM
apache's Avatar
Thanks Bushy!! that otta keep me busy for a while
Old Oct 4, 2004 | 12:28 PM
jonmurr's Avatar
The controller inhibits 4th gear until it sees 60 degrees engine coolant temperature. The transmission temperature sensor is actually just a switch that toggles at 270 degrees plus or minus 5 degrees. I agree this is a bit late.
Ghostrider
Dec 24, 2011 12:22 PM
drewallen42
Jun 11, 2007 09:23 AM
BC847
Competition / Pulls / OffRoad
0
Feb 7, 2007 09:42 PM
pappygtb
May 31, 2003 12:37 AM
TPilaske
Jan 28, 2003 10:47 AM
