auto trans fluid level
Old Apr 9, 2008 | 08:19 PM
archer39's Avatar
i am about to change out the trans fluid in my 93 w250 and i was just wondering if a deep pan will affect the fluid level the dipstick reads? i don't know how much extra the pan holds because it was on the truck when i got it. but it is deeper than a stock one. Also is ATF+4 ok to use in it?
thanks
Old Apr 9, 2008 | 09:08 PM
Carp's Avatar
The reading of the dipstick does not change with a deeper pan. The +4 fluid is fine to use.
Old Apr 10, 2008 | 04:50 PM
Most of the deep pans add about 2 qts.
Old Apr 10, 2008 | 08:56 PM
archer39's Avatar
well i am short a few quarts. I added 6 qts and it is at the bottom of the dip stick.
Old Apr 10, 2008 | 09:17 PM
sdstriper's Avatar
Fil it up, did the filter have an aluminum spacer behind it by chance?
Old Apr 11, 2008 | 07:18 AM
archer39's Avatar
nope no spacer
Old Apr 11, 2008 | 10:32 AM
93beater's Avatar
stock a518 calls for 4.5 deep pan will proab call for 6 or 7 start with 6. check the level on the dip stick in neutral while running it needs to be at the same mark where it reads *safe*
MTC
Dec 12, 2010 02:48 PM
johnfarrow
Sep 28, 2007 03:36 PM
icrider
Sep 27, 2006 03:10 PM
Dieselcamper
Jan 28, 2005 12:39 PM
teckert
Jun 9, 2004 12:34 PM
