Auto tranny rebuild?
Old Feb 25, 2010 | 09:08 PM
Fred the Farmer's Avatar
hi all,
alright so my tranny is in dier need of some rebuilding. It slipps quiet a bit and i can definantly tell not all of the power is hitting the pavement. I was wondering what all i should be upgrading other than the torque convertor.
Old Feb 25, 2010 | 09:30 PM
93Fury's Avatar
Depends on how much money you want to throw at it. I say along with a converter do a valve body, upgrade clutches, and a 2nd gen flexplate if not an aftermarket.
Old Feb 26, 2010 | 11:26 AM
i was looking to spend about 1200, i think i'm gonna get the transgo shift kit, the red eagle performance rebuild kit, and a georend convertor.
Old Feb 26, 2010 | 11:43 AM
Good choices. Just make sure the red eagle rebuild kit doesn't come with the valve body upgrade stuff, if it does than a transgo kit wouldn't be necessary.
Is the red eagle kit just the clutches and steels and bands and stuff?
Try to find a stock 2nd gen flexplate, they're much stronger than a stock 1st gen flexplate
Old Feb 26, 2010 | 11:47 AM
BC847's Avatar
1st Generation Admin
What do you intend to do with the truck? Grocery-getter? 10 second dragster?
Old Feb 26, 2010 | 12:04 PM
i am wanting to pull and race pretty good.with some good daily drive ability.
Old Feb 26, 2010 | 12:12 PM
Pull a sled or pull a trailer?
If towing, upgrading the transmissions cooler wouldn't be a bad idea, if you dont already have the auxillary trans cooler mounted under the bed.
Old Feb 26, 2010 | 02:51 PM
pull a trailer and i don't have a tranny cooler at all.
Old Feb 26, 2010 | 10:47 PM
is it posssible to not have a cooler
Old Feb 27, 2010 | 12:05 PM
Not sure what you mean by that? These trucks all had two coolers from the factory. One oil-to-water beside the engine, one oil-to-air behind the grille. If yours are missing someone's been up to butchery. For empty cruising around you can get away with one or the other being gone. A working truck needs all the trans cooling you can throw at it.
Old Feb 28, 2010 | 12:43 AM
it has the one in front of the grille, figured that out today when doing the KDP.
Old Feb 28, 2010 | 01:52 AM
Rick 12v CTD's Avatar
you should check to see if the other one is there.
It just looks like a big cannister on the side of the engine, the passenger side to be exact. Under the turbo. It has a couple steel coolant lines running to it. 2 coolant lines. One from each end, and then IIRC it has 2 more going from the trans to the bottom side of the cooler. you can't really miss it if it's there.
Old Feb 28, 2010 | 10:44 AM
yea i checked that i also have that one, huh i didn't know either of those were trans coolers. My dads 93 has an under the bed cooler and i thought that at all 1st gens did off the line i guess not.
Old Feb 28, 2010 | 02:57 PM
Nope, that was a dealer installed Mopar accessory.
Old Feb 28, 2010 | 07:54 PM
i see, when i rebuild mine i'm going to install another cooler, where would be the best place to put it.
