Anyone swapped in a Ford 10¼ axle?
Old Nov 21, 2011 | 07:52 PM
u2slow's Avatar
I have a blown up D70 in my 'spare' D250. Rather than blow a lot of $$$ on rebuilding it, I can get a '95 Ford 10.25" axle in 3.54 for $150. Slide off drums are a nice perk. I can even change to 3.08 ratio later if I want
Anyone done this? What stumbling blocks did you run into?
Old Nov 21, 2011 | 08:11 PM
simplysmn's Avatar
Ide go Corp 14 bolt off of a Chevy they swap right over and are just easier to deal with
Old Nov 21, 2011 | 08:16 PM
measure the space between spring perches
I think fords have that goofy 4 bolt flange where the the driveshaft bolts to the rear,
Old Nov 21, 2011 | 08:19 PM
u2slow's Avatar
I have a 3.73 14b that needs full going through. I have found the 3.42 and 3.21 ratios before, but very hard to come by. A 3.54 Ford axle with slide off drums and posi for $150 is looking good right now.
EDIT: '95 F250 is a yoke. I used to have such a truck. I know what u mean though, my E350 and a spare superduty diff I have uses a round flange.
Old Nov 21, 2011 | 08:21 PM
simplysmn's Avatar
I believe on the ford you will have to move the spring perches but on the chevy Check Craig's list you could find 1 for that price also less to hassle with JMO
Old Nov 21, 2011 | 09:17 PM
Chevy 14 bolts came standard with 3.21 gears too, and 3.42's were common as well.
Old Nov 21, 2011 | 10:52 PM
u2slow's Avatar
I measured my D250 and the springs measure 43". 73-87 Chevy 3/4ton is 42" if I remember correctly. If that's the case, the springs are going to be pulled together?
3.21 and 3.42 are hard to find for the full-float... I have encountered exactly 4 sets of these in my life - and only 1 set while working at a GM truck autowrecker for 4 years. OTOH, I could build castles with 3.73 and 4.10 sets.
I may have a lead on another Dana 80, although having a driveshaft shortened seems like more of a hassle than moving perches.
Hmmm.. what to do...
Old Nov 21, 2011 | 10:55 PM
simplysmn's Avatar
Yeah but if you have to bring the spring's in it end's up being a 1/2 inch per side ? and it's not
noticeable
HOHN
76
Oct 14, 2008 12:29 PM
rbrettctd
Jun 30, 2007 09:21 AM
Mglass1045
Jul 13, 2006 10:00 PM
2broke2smoke
Feb 5, 2005 07:42 PM
