Anyone have a Gear Vendors OD wiring diagram?
Old May 13, 2008 | 09:43 AM
leadvilleram's Avatar
Thanks for the pics. I should be able to figure out the switch setup. I will probably just order a switch from GV, I don't want to spend much $, if the thing is dead anyways, but I don't want to short it out by trying to rig a switch to possibly the wrong wires. Worst case, I will just run a toggle straight to the solenoid and bypass the system. I really just want the OD for highway.
6" of snow on the ground this morning...maybe I'll get to it in a day or two now.
I did read about fluids...
The Oil recommended by GV is GM 12346190 or Mopar 4874459 or Castrol Syntorque. All about $20/qt. synthetic gear oils, luckily it only takes about 1 qt.
I saw an Amsoil product that works too, can't find that part#.
Old Dec 28, 2008 | 09:44 AM
PapeCAT's Avatar
So did you ever get your Gear Vendors OD/UD unit working.
Old Dec 28, 2008 | 09:56 AM
I hooked up the shift solenoid up to a toggle switch and bypassed the computer and she works like a charm! I ordered a dash control switch and owners manual, but have had no time to install that stuff, so I just toggle if I need OD. It really lowers the rpms, nice for the highway!
Old Dec 28, 2008 | 10:04 AM
PapeCAT's Avatar
I was thinking of bypassing all of that gearvendor idiot proof computer junk too and just toggle it... I guess you're just supposed to use it above 20 mph or so? Also not use it with an E brake? ( I don't have one)
Old Dec 28, 2008 | 10:25 AM
You have to be careful not to engage it or forget to disengage before using reverse, or 4wd...you don't want different final drive ratios engaging on each axle...bad noises and shearing steel may bum you and the diff's out! That's why they have the computer. I'm the only one that drives my rig, so I'm OK with it.
Old Dec 28, 2008 | 10:30 AM
How much percent does it cut it down by? you have any idea? like is it a 20% overdrive or what....
So it shifts 1-2-3 gear and then you lock it in on the highway or is it always engaged even when going from a dead stop.
Old Dec 28, 2008 | 10:32 AM
PapeCAT's Avatar
Yeah OBV no 4x4 with GV engaged.
The rig is going to be an idiosyncratic beast no matter what. If someone wanted to drive it, they'd have to not use the GV. The other thing is that I'll also have a Brownie aux trans behind the GV for triple OD. Would have to make sure that both of those are in 1:1 if I wanted to go 4x4. But who needs to go over 35 in 4x4? That speed is perfect for 4:10s and 4th on the getrag. 1:1:1:1:[4:10]
Old Dec 28, 2008 | 11:05 AM
Bruce M's Avatar
I am looking for the Gear Vendor Tailhouse section to fit a 1990 727 diesel trans.
I have the 18" section that fits a 1990 Dodge 727 gas van.
Bruce
Old Jun 29, 2011 | 04:55 PM
Shiny's Avatar
Does someone have the wiring diagram again? The one in this thread is gone
I have the same setup in my truck as FlashGordon has but all the wires are cut that go into the VSS.
I need O/D. My speedo bounce around or doesn't work at all most of the time.
-Shiny
Old Jul 7, 2011 | 09:34 PM
Shiny's Avatar
Hello... hello... anybody...
-Shiny
Old Dec 7, 2011 | 10:12 PM
Shiny's Avatar
Tumbleweeds.... crickets....
-Shiny
Old Dec 8, 2011 | 12:02 AM
BILTIT's Avatar
This is right out of the manual, not sure if you can make it out.
Old Dec 9, 2011 | 07:49 PM
Thunderhog's Avatar
i called Gear Vendors, told them what I had, and 3 days later had an install/diagnosis manual in the mail. great company! just call them!
BRUISER
Sep 7, 2008 12:54 PM
subspd
17
May 14, 2007 06:48 PM
JohnInNH
15
Sep 3, 2006 08:22 AM
mhuppertz
Aug 19, 2006 09:17 AM
Brambles
Oct 18, 2005 04:36 PM
