anyone ever run an industrial motor in their truck?
Just wondering if the motors are that big of a difference. As in is the injector pump set up different because it's basically a no load motor, or the injectors different, timing maybe. It's out of a low hour generator.
don't forget the legal side of putting a non epa engine inside a highway use pickup... big fine$$$$ No big deal but just hope you don't get in a wreck and/or have lawyers crawling around your rig trying to find liability/fault for an accident or citation.
The motor is stuffed in a 93 dually right now. The guy center punched a tree with it. It's a 4wd, and I could get it for 2500 bucks. He said it ran like a raped ape. I'm thinking of converting my 2wd 79 crew cab to a 4wd diesel with it.
Just not sure if the motor will last with that pump the way it is set up. Guess I could always just replace the pump.
I'm not entirely sure what the message above is saying about collecting parts. The donor truck I'm looking at with the generator engine is a complete 4wd dually with 3K miles on it. Everything I need for the conversion is there.
And diesels are still pretty spendy around here. I have found quite a few deals though. The last was a 91.5 with a bad oil leak and the 5 speed in the bed for 1000 bucks. I fixed the KDP crack and unjammed the shift fork in the getrag, swapped the front 60 with a 44, then sent it down the road for $3500. guy was doing a diesel swap in his chevy and didn't need the 60 so I kept it.
dodgetrucker75
Sep 21, 2009 12:52 PM
hilclmr2
Jun 17, 2008 04:37 PM
