Anybody know where to find FRONT BRAKE PADS with WEAR SENSORS/MECHANICAL TABS
Old Mar 21, 2016 | 11:48 PM
vintageracecar's Avatar
Anybody knows who sells Front Brake Pads for my 1990 Dodge D250 2WD with a Cummins.
Having trouble finding pads with Wear Sensors / Mechanical Tabs.
Tired of needing to replace the rotors every other time, the pads go away. My truck is automatic and that fact makes it a little harder, to be kind on the front brakes. (Cummins keeps on pushing, even @ 800 Rpm idle)
Any help is greatly appreciated.
Mike
Old Mar 21, 2016 | 11:53 PM
Philip's Avatar
Mike
I have been looking for the same thing. Wear sensors I could care less about. The mechanical tabs is what I want. Getting tired of the trashy stick on/ fall off anti rattle garbage they are using now.
The only rattle my truck has is the front brake pads.
Old Mar 22, 2016 | 01:08 AM
How quickly are you burning through a set of pads? Why not make changing front brake pads part of a yearly service procedure?
Old Mar 22, 2016 | 07:22 AM
I never let my pads (on any of my vehicles) get below half worn. This prevents the intense heat from the rotor, transferring through a thin brake pad into the caliper, to heat up / boil / contaminate the brake fluid in the caliper.
Cheap insurance, IMO.
Once a year, or ever other year sounds about right. If the rear brakes are working well, then it can last even longer.
Old Mar 22, 2016 | 01:56 PM
At times I'll only get 35-40K Miles out of a set of Front Pads. I usually do that in less than 6 month, so to make the changing front pads part of a yearly service does not work well for me.
I switched to Synthetic Oil to be able and go on a Cross Country Trip, without having to change Oil while out of town.
For the Front Brake Pads all I want, is for the darn pads to tell me when they are almost done, so I can replace them, without having to buy new rotors.
That should not be too much to ask for. They are making such pads for most other vehicles, why not our 1st Series Dodge's ????
Old Mar 22, 2016 | 09:41 PM
You put 70 to 80 thousand miles on your truck in a year ???????
Really ????????????
Amen, brother.... that's awesome..
If you're handy with a welder, bend up a piece of 16 or 14 gauge sheet metal, and weld it to the pad.
Old Mar 22, 2016 | 10:02 PM
Really ????????????
Funny you mentioned that T-man...I was thinking the same thing. PITA I know, but if it saves you the cost of rotors might be worth it.
Old Mar 22, 2016 | 10:44 PM
Really ????????????
Yup, most of it is hauling a trailer. Cummins got almost 500K on it and is still working the way it should.
Guess I could weld tabs on the sides. Probably better off buying Riveted Pads, to make sure the glue does not come loose after welding them. Not even sure if you can get glued pads for a 3/4 top PU.
Would you put them on the front or rear of the pads ? Considering the way the wheel / rotor turns. Probably on the front, so its the last thing the rotor scrapes, after going through the caliper. And on the outside, correct ?
Old Mar 22, 2016 | 11:02 PM
My pads have the squealers on the inside, so that the sound reflects off of the wheel wells. I believe it should be on the trailing side, otherwise the could potentially bend inward towards the pad.
That's so cool your running that king of mileage. The front wheel bearings are , I would think, expected to be repacked every 30 k or so, but I could see where someone such as yourself it's just not practical doing so.
Post pics of the process. Cool project, albeit a bit small
Old Mar 23, 2016 | 07:55 AM
Philip's Avatar
Dodge said front bearing repack every 12K or 12 months.
Old Mar 23, 2016 | 08:53 PM
Jim5870's Avatar
Use D350 brake pads instead of D250 bake pads.
The D350 brake pads have more total pad area and fit right in.
Old Mar 25, 2016 | 10:58 AM
mknittle's Avatar
My Raybestos have em. i just dug the loaded calipers I got about a year ago out. and low and behold there they were.
Old Mar 25, 2016 | 02:14 PM
Do you have a pic?
Old Mar 25, 2016 | 06:02 PM
mknittle's Avatar
here ya go.Please excuse the bad pictures I am nit used to my new point and shoot.
Attached Thumbnails Anybody know where to find FRONT BRAKE PADS with WEAR SENSORS/MECHANICAL TABS-dscn0029.jpg   Anybody know where to find FRONT BRAKE PADS with WEAR SENSORS/MECHANICAL TABS-dscn0028.jpg   Anybody know where to find FRONT BRAKE PADS with WEAR SENSORS/MECHANICAL TABS-dscn0027.jpg   Anybody know where to find FRONT BRAKE PADS with WEAR SENSORS/MECHANICAL TABS-dscn0026.jpg   Anybody know where to find FRONT BRAKE PADS with WEAR SENSORS/MECHANICAL TABS-dscn0024.jpg
Old Mar 25, 2016 | 06:29 PM
Philip's Avatar
Those are the trash type rattle pads. They do rattle. The glue on type just fall apart after a short time. Then the rattle comes back agin.
The original brake pads have a clip riveted onto the back side that clips into the caliper piston.
