Any options for piston pump to filter line?
Old Jun 24, 2012 | 02:12 PM
PeytonMaterne's Avatar
My stock diaphragm lift pump has bit the dust on my daily driver. I installed a low pressure piston pump on one of my other rigs and I didn't like cutting the tappet insulation to make room for the line. It is hard to get at and hard to cut accurately and it looks pretty crappy. Is there a "kit" offered that has some flexable line with the correct fittings for each end? Anyone have pics of their setup? Who has the best deal on the Lppp right now?
Old Jun 24, 2012 | 03:32 PM
Moparbubba's Avatar
Ofi has the best deal on the delphi pump what dap also sells for way more. i cut my insulation it wasnt bad you cant see it unless you look up under it. I have pic of mine in my ole shakey upgrades thread
Sent from my DROIDX
Old Jun 24, 2012 | 03:37 PM
#2isgreen's Avatar
Unless it's untaxed, then it's red.
The trick with the insulation is to heat it up. Use a heat gun and it will cut like butter.
Old Jun 24, 2012 | 04:25 PM
jesussaves's Avatar
where was that little bit of info when i did mine
Bruce M
Mar 11, 2011 12:20 AM
Crossy's son
Sep 8, 2009 03:34 PM
Elohim1
May 5, 2008 07:57 AM
ryan10
Mar 11, 2008 08:12 PM
CTD99
13
Aug 23, 2005 10:55 PM
